| X10 General Discussion Discussions for CM11, CM12, CM15, CM17, TI103/213, Powerlink 1132, Lynx and all other X10 related plug-ins |
March 17th, 2012, 11:00 PM
Seer
CM 15 & Ninja ?
Was going to give Blade's Ninja control plugin a test spin, untill I discovered that his CM19 driver only worked under Windows 7 23-bit...unfortunately, my system is 64-bit, and I REALLY don't want to reformat and reinstall the 32-bit version.
That being said, the CM15 USB interface DOES transmit signals to the pan & tilt cameras.....however, only through the remote control...but does that not indicate that the CM15 is capable of accepting variables and sending them on the the pan & tilts ? ( Oh, and this works, with or without the CM19 attached).
Now, I used to use Case's CM19 USB plugin when I used Homeseer 1.x, along with his web-page interface. That doesn't work under Windows 7 & Homeseer 2.
So, I guess my question is....does anybody know if the CM15 plug-in accepts variables from programming, and if so, what would the syntax of those commands be ?
March 18th, 2012, 02:09 PM
OverSeer
I run Blade's Ninja Control under XP Pro and seem to remember having to download a seperate driver which was detailed in the docs.
A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
HS Pro V2.5.0.76 (reverted back), HS Touch Server V1.0.0.77 on a Foxcon Atom D525
DooMotion V2.4.0.0, DooMenuBar V2.4.0.5
RFXCom V14.00.67, RFX-Charts V1.1.0.10. SNEVL CID V1.29.10, SNEVL Latitude V2.1. Btraced V1.1 Beta, and a lot of Jon00 stuff
BLBackup V1.0.20, BLGarbage1.0.5.0
My Weather Station
March 18th, 2012, 07:57 PM
Seer
Quote:
Yup, for 32-bit only.
March 20th, 2012, 02:38 PM
OverSeer
Try dropping Blade an email and see if he knows of any download you could get.
My Weather Station
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is Off
