Go Back   HomeSeer Message Board > Off Topic
Off Topic Post your jokes, funny stories, current events and antecdotes here.
Old March 29th, 2012, 12:22 PM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
Seer Master
Circles Wow! - Power Curtain Rail - REALLY affordable
Hey Guys,
Check this out! This company offers motorized blind, rolling shade and vertical blind control. The thing that makes this nice is that the pricing seems really affordable.
If you have used these in the past, can you please post your experience and how you liked/disliked the integration and how HS has been able to work with it?
Thoughts?
http://www.powercurtain.com/
Roller Shade - Up to 8 feet long
Drape control
And then you can get this box to connect up to homeseer:
http://www.powercurtain.com/connectivity-3.html
Connection:
BLACK 5 touches RED 1 = UP & STOP (S1)
YELLOW 4 touches RED 1 = DOWN & STOP (S2)
YELLOW 4 touches BLUE 2 = SET (S3)
BLACK 5 touches BLUE 2 = CONFIRM (S4)
YELLOW 4 touches GREEN 3 = R & + (S5)
BLACK 5 touches GREEN 3 = S & - (S6)
Technical Specifications:
• Input voltage: 220V/50Hz, 110V/60Hz
• Output Voltage: 24V DC
• Power Consumption: 25 W
• Opening and closing Time: 6 Sec/M
Then, you can hook it up to this box for Zwave control:
http://store.homeseer.com/store/ESI-...ller-P853.aspx
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.28 - BLStat - HSPhone - HSTouch Srvr 1.0.0.60 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - and others...
Old April 6th, 2012, 06:18 PM
Seer Master
Default
Anyone have any thoughts on this? What are you using for shade control?
Old April 6th, 2012, 06:44 PM
Monk's Avatar
Monk Monk is offline
Seer Master
Default
First thoughts - $216.00 per window for the Z-Wave controller alone, not counting the "Motor kit" for the curtains?
A quick look shows another ~200.00 for the motor kit.
So, a minimum of 400.00 per window to automate each of my windows if I figure this right. Not sure that's something I would consider.
Old May 4th, 2012, 06:55 PM
EricE's Avatar
EricE EricE is offline
Seer
Arrow
Quote:
I was going down this path and am just amazed at how expensive this stuff is.
Until I realized I have two Hunter Douglass blinds on windows that are on windows that are on the upper half of my two story family room - and they were both well under $500 - I think more like $450 including tax. They are motorized and controlled by IR. I currently use rechargeable batteries in them and have to change the batteries every year and a half or so, but they can be hard wired to a permanent DC source if desired.
So I think I'm going to get an IR controller that HomeSeer can control and experiment with that. If it works reliably enough on the ones I have, I may get two more for my lower windows in my living room and take it from there.
HTML code is Off
Copyright 1998-2011 HomeSeer Technologies, LLC
