Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > CFGuy Plug-Ins and Scripts > WeatherXML
WeatherXML Discussion area for WeatherXML
Old May 4th, 2012, 12:01 AM
bernieb bernieb is offline
Seer Deluxe
Default UV from Weather Underground
Hi Jeff,
I registered for the Weather Underground API and all went well. I did it because I wanted to retrieve the UV value for the day. For the life of me, I can't find under which device this displays. Would you mind pointing me in the right direction please? Also is there a way that I can retrieve the Pollen Count?
Thaks
BernieB
Old May 4th, 2012, 12:20 PM
CFGuy's Avatar
CFGuy CFGuy is offline
Have A Blessed Day
Default
Go to the Advanced Setup page.
In the devices setup section you should have the following for UV.
Jeff Farmer
HS3 Plugins: Restart,
HS3 Plugin Currently Working on: WeatherXML, Pana Blu-Ray, Random Phrase, Tracker
HS 2.5.0.75
HS2 Plugins: HSTV3, Misc Plugin (Random Phrase, Tracker, Restart, Links Editor, Movie Broadcast), weatherXML
My Scripts: Movie Manager 3
Software: POP3 EMail Package, ACT TI-103, NeoSpeech Voices, SpeakEasy, UltraLog, ACRF2, UltraPioneerAVR, HSTouch, HSTouch Android, tenHSPower, UltraMon
Hardware: Schlage Z-Wave Lever Lock x2, Way2Call Hi-Phone, WGL 800, TI-103, Z-Troller, Pioneer 1120, Pioneer 1021, Pioneer 1122, Panasonic BDT-110, Panasonic BDT-210
Old May 4th, 2012, 12:24 PM
CFGuy's Avatar
Have A Blessed Day
Default
I don't know of a source for pollen.
Weather Underground said they get their pollen info from someone else and can not include it in the API info.
Jeff Farmer
HS 2.5.0.75
Old May 4th, 2012, 04:28 PM
GatorEye's Avatar
GatorEye GatorEye is offline
Seer Deluxe
Default
I asked them the same thing with the same response. They said they get their data from pollen.com
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Old July 26th, 2012, 01:07 PM
BrunDog BrunDog is offline
Seer Deluxe
Default
My UV always reports 0.0 in the status screen, despite WU having a UV number for my area.
There is a device code, and no errors... Any idea why I do not get the UV reported in WXML?
-BD
Old July 26th, 2012, 02:24 PM
Pete's Avatar
Pete Pete is offline
OverSeer
Default
Try turning on debug and having a look at the logs when getting data from WUN?
Maybe removing your variable, redoing your primary weather (WUN) to say something else, then back to WUN? I see a UV condition in there as a variable that hasn't changed since 11/2011. I have WXML running on two HS boxes now pulling the weather from WUN and the numbers for UV match. I also pull the numbers autonomously with mcsSprinklers (running on Linux) from WUN and its the same number.
Homeseer User
HSPro 2.5.0.80 HSTouch 1.0.0.72
PIs: ACRF2 | BLOutgoing Calls | BL RFID | BL UPS | CheaperRFID | Cumulus | CumulusR | HAI | UPB | mcsXap | Maestro | HSTouch | MCSTemperature | CM11 | WeatherXML | HSPhone | UltraLog | WAF AB8SS2 | SnelvCID | Jon00PerfmonHS2 | MaxUpTime | Jon00CCNM | mcsSprinklers | NeoSpeech | Russound
HW: Core2Duo | Atom D525 | HAI OPII | Russound CAA66(s) | Russound KPL(s) | WGL800(s) | Quatech QSE100D (s) | Z-Troller | XTB IIR | XTB | Insteon PLM | Edgeport/8 (s) | UPB | Way2Call | DigiAnywhere USB | Zoneminder (Ubuntu) | Temp08(s) | Temp05 (s) | DS9097(s) | NetCID(s) | Leviton Vizia RF+Z | MiCasa Vera 2 | Ananiah Electronics RFID(s) | HST-IWAR7 (Android) | Omnitouch 5.7 (s) | Omnitouch 5.7e (s) | Touch (WinCe) | Touch (XP) | Touch (Linux) | Davis Vantage View | Fine Offset | AAG | Dallas Instruments | Hydreon RG-11 | Foscam | Grandstream | Ubiquiti | HAI Omnitstat2 | HAI Touch Hub | HAI Video Server | WGL Rain8Net(s) | Seagate Dockstar (Arch Linux)
Old July 28th, 2012, 10:25 AM
Seer Deluxe
Default
The log never showed anything abnormal. It said:
7/28/2012 10:10:00 AM* weatherXML_dev* Set UV
It has always done this but the value did not update to match WU. Ironically however, today the value updated properly. Go figure. Maybe WU changed something on their end, because it says for UV, "# out of #", and I dont remember the out of thing. Will watch and report back.
-BD
Old July 28th, 2012, 11:24 AM
Pete's Avatar
OverSeer
Default
On a side note: the reported WUN moon phase is off and there is a WUN ticket opened for it.
Its difficult though as most "at home" ISP connections whatever they may be have basically little or no QOS; leaving you to the mercy of the internet and what data will be provided to you (free mostly but changing).
A while back tried the "light sensor" way and the temperature sensor in the jar to figure out UV and it kind of works. I use it mostly in the calculation of the ET for the sprinklers; without the UV data then the calculations are off; et al. I did notice a neighbor (that I walk with) is very sensitive to the sun and does wear protection whether its a sun block or clothing; but she doesn't utilize the UV number for that.
Homeseer User
Old July 28th, 2012, 01:54 PM
Seer Deluxe
Default
Yeah, not having the right UV number or moon phase won't change my life much, but being the OCD HA freaks we are, we like everything to fall in line.
Weird thing is today it is hit or miss. Sometimes the number is accurate, other times it is 0.0. The log gives no clues and always reports properly. My guess is a data type error.
-BD
Old July 28th, 2012, 04:22 PM
Pete's Avatar
OverSeer
Default
Me neither; unless I start believing what I see on the computer versus what I see outside.
Homeseer User
HTML code is On
Copyright 1998-2011 HomeSeer Technologies, LLC
