I am trying to setup notifications for the sensor message panel, and I am not having any luck. I am using the example sensor.vb script from the user manual, and am having no luck.
I have been testing the script in an event as shown in the attached photo. E-mail is configured to send correctly and has been confirmed. And below warnings in the log.
Also, there is currently a sensor message panel message.
Any idea what I am doing wrong?
Sub Main(Optional ByVal pParms As String = "") Dim rfxcom As Object message = hs.PluginFunction("RFXCOM", "", "GetLastSensorMessage", nothing) hs.SendEmail("xxxx@yahoo.com", "xxxx@gmail.com", nothing, nothing, "RFXcom Sensor Alert", "message", nothing) hs.PluginFunction("Pushalot", "", "SendPushalot", New Object() {"RFXcom Sensor Alert", "message", True, False, "Homeseer", "http://homeseer.com/updates3/icons/Plug-In.gif", 1440, "", ""}) End Sub
[COLOR="Red"]Mar-01 12:59:37 PM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\RFXCOM_sensor_pushalot_e-mail.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases. Mar-01 12:59:37 PM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\RFXCOM_sensor_pushalot_e-mail.vb: 'message' is not declared. It may be inaccessible due to its protection level. Mar-01 12:59:37 PM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\RFXCOM_sensor_pushalot_e-mail.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases. Mar-01 12:59:37 PM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\RFXCOM_sensor_pushalot_e-mail.vb: 'message' is not declared. It may be inaccessible due to its protection level. [/COLOR]
