When scripting with the hs.newtimeevent() function.
I would like the ability to set the
"Do Not Log This Event" check box on the created event.
I use the hs.newtimeevent() function extensively.. and this would help reduce the amount of information in the log. (unless i want to debug.. then i would not set the checkbox in the script)
I am not sure if this would also take care of the issue raised in the thread:
http://board.homeseer.com/showthread.php?t=136771
This thread is asking for the ability to disable the message
| Info | Deleting event after run "Eventname"
that is logged when a delayed event is automatically deleted.
These might be two separate issues. I do not know.
Thank you.
