Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old August 1st, 2009, 05:44 AM
Simonk Simonk is offline
Question Using " within hs.Launch parameters
I'm having trouble tryiny to use a command in a vb.net script that uses "
This is what I have tested with a event :
Apllication Path : C:\Program Files\HomeSeer HS2\LedDisplay
Parameters : -NoServer -NoGui -DeleteRegex "" -SendText "Testing Still 1,2,3,4,5,6,7,8,9,0"
I want to put this into a script rather than having a seperate event and also want to use the variable PlayList in the Parameters.
I've tried to use the following line in my script and it runs without any errors but doesn't do anything !
hs.Launch("C:\Program Files\HomeSeer HS2\LedDisplayCtrl\LedDisplayControllerGui.exe", "-NoServer -NoGui -DeleteRegex -SendText """ & PlayList & """ ")
I'm thinking that it is something to do with the " on the -SendText commands, it wants -sendtext "text to send".
Any help appreciated.
Simon
Old August 1st, 2009, 07:01 AM
jon00's Avatar
jon00 jon00 is offline
Default
This is always a difficult issue and know the problem. I noticed you omitted the 2 quotes after -DeleteRegex which may be required.
Try
hs.Launch("C:\Program Files\HomeSeer HS2\LedDisplayCtrl\LedDisplayControllerGui.exe", "-NoServer -NoGui -DeleteRegex " & """" & " -SendText """ & PlayList & """ ")
Jon
Old August 1st, 2009, 07:21 AM
Default
Try
That sorted it
