Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old August 11th, 2009, 12:44 AM
nslmanu nslmanu is offline
Default Simple guest customzable page without password but all admins pages with passwd !
Hello,
I don't know if it's possible but i already try to test it.
Actually i have my HS2 website with only 1 user ( mine which is admin ) with a password to log on the website.
But what i'd like to do is to create a simple web page, customizable, where i can access it WITHOUT a password, so directly.
Do you think it's possible with HS2 ?
The website is at home ( normal ) and i'd like to monitor it from a compagny specialized in monitoring. But theu can't monitor web sites where there is a password. Only direct pages.
So if you think there is a solution, please tell me
Thanks for all people for reading me.
Regards
Manu
Old August 11th, 2009, 02:10 AM
jon00's Avatar
jon00 jon00 is offline
Default
With Homeseer's web site setup, you can set custom page 1 so that it can be viewed without a password. This custom page 1 can be set as the home page if you wish.
Take a look under setup/web site tab.
Jon
Old August 11th, 2009, 02:22 AM
Unhappy
Hi and thanks
I already test it and it doesn't work.
Custom Web Page 1 Title : test
Custom Web Page 1 URL/Link : test
Require a Password for Custom Page 1: No
Use Custom Page 1 as Home Page: yes
And when i go in my url : https://ip : i'm already asked for a password.
I already restart HS2 ( last version ) in case off but without success.
Fyi : I have only one user : me admin , no guest no other kind of users.
what i've missed on this screenshot ?
Old August 11th, 2009, 08:52 AM
nightwalker nightwalker is offline
Default
You may have to setup a "Guest" user account to get it to work.
Marty
XPpro SP3 /w HS 2.4.0.11
Old August 11th, 2009, 10:11 AM
huggy_d1's Avatar
huggy_d1 huggy_d1 is online now
Default
Originally Posted by nslmanu View Post
Hi and thanks
Custom Web Page 1 URL/Link : test.html
And when i go in my url : http://ip : i'm already asked for a password.
Try as edited above (see links below):
http://ip/test.html
Then try http://ip
If that works, try https://ip/test.html
Then try https://ip
I don't think HS will render a web page without a page type (.htm, .html, .asp, .aspx, .asen, etc.)
If that doesn't work, you may have to create a guest/guest account with guest access so the system can default that first page to guest/guest access. I would hope not, but never tried it.
Hope that helps.
huggy_d1
Automating made easy
Old August 11th, 2009, 12:59 PM
Default
Hi and tks a lot ...
Actually i have created a guest/guest account with guest rights.
I have created a test.html page.
And i'm still prompted for a password for the test.html or http://IP/test hs2 page declared in the setup.
I don't really know what i have missed !
Old August 11th, 2009, 03:20 PM
sbwright's Avatar
sbwright sbwright is offline
Default
On the "Web Server" tab do you have the "Require Password for Local Area Logins: " set to NO....?
Brian
Old August 11th, 2009, 05:07 PM
huggy_d1's Avatar
Default
Hi and thanks
To me, it looks like everything is set up correctly. It's identical to how my system is configured, and for my "home" page, AFAIK HS doesn't prompt for a password for my custom page 1.
huggy_d1
Old August 11th, 2009, 05:15 PM
Rupp's Avatar
Rupp Rupp is online now
Default
Ensure that you are not requesing any HomeSeer data on your home page or this will request a login.
-Rupp
Old August 11th, 2009, 05:35 PM
huggy_d1's Avatar
Default
Aha, that might be! My 'home' page is nothing but straight html.
huggy_d1
