| HomeSeer HS2™ Specific General discussion about HomeSeer HS2. |
August 25th, 2009, 04:34 AM
Multiple conditions in HS2
Hello,
After trying many ways to put more than one conditions without results, i post some questions :
In fact i'd like to check this :
- If temp sensor value X is higher OR lower of Y at least of Z mins , sent an email.
- If temp sensor value X is higher than W AND lower than Y at least of Z mins , sent an email.
- If Sensor X is On AND Sensor Y is Off AND value Z is higher than W AND lower than V ( or just value Z is higher OR lower than W ) at least of B mins, sent an email.
The only thing i can do it only
one condition as the screenshot.
There is some possibilities to put more than conditions as these one ?
Thanks a lot in advance ...
Regards
August 25th, 2009, 05:49 AM
Checkmark the Apply conditions box this will allow for multiple conditions - another option is script
August 25th, 2009, 05:53 AM
Yes i know for the Apply check box ... but i can't do them for the others conditions.
With scripts : i don't know vb.
August 25th, 2009, 08:35 AM
Super Seer
I'm not sure I understand what you mean. For reference see below.
Each time you click on the 'Submit' box you can add an additional condition. All conditions within a group are connected by 'And'. Groups are connected by 'Or'.
That said, although the interaction of the conditions is limited only by your ingenuity, the conditions you describe are complex. They will take some careful thought to get right. A script would be more straightforward, but will require some learning.
HSPro 2.4.0.11 || Plug-ins: Stargate | ACRF2 | VWSCSV | UltraStatus | BLRFID | PowerTrigger | NetCam | ActiveBackup | UPB | mcsXap | UltraMon | Russound
Scripts: Weather XML | PerfMon | VDGraph | ImageBuilder
HW: EeeBox | JDS Stargate | NetworX NX-8E | CAV6.6 w ABUS | Slink-e / CDJ | Compose switches, keypads, firewalls | WGL800 | RFXCOM LAN2 | Quatech QSE100D | LaCrosse 2310
August 25th, 2009, 09:41 AM
Super Seer
Even scripting all this would be complex. Without resorting to scripting, your time requirements are going to necessitate the creation of a couple of extra devices to track the True time, and you'll need multiple events as well to accomplish all this.
First, apply some Boolean Algebra to your condition set. As you've described the requirements, they can be reduced to:
1. X not equal to Y
2. X greater than W
3. X On and Y Off, AND Z greater than W, AND Z less than V
Create events:
1. Set new device M ON if one of the first two conditions are true.
2. Set device N ON if the third set of conditions is true.
3. Test M for "has been on for at least" Z minutes. The action here would be send the email and reset M to Off.
4. Test N for "has been on for at least" B minutes. The action here would be send the email and reset N to Off.
If Rick or Rich are listening, a "Group has been true for x seconds" option would be nice.
Automate everything, modify the rest... but remember... For every action, there is an equal and unexpected reaction.
August 25th, 2009, 11:54 AM
Thanks a lot very much,
So i need to use a Virtual device ?
Set On in the actual condition in not true ... and if the Virtual device is ON at least 5 minutes so send an email ....
correct ?
( in fact i search how to put ALL IN ONE event ) but it's impossible.
| Thread Tools |
| Display Modes |
Hybrid Mode
