Go Back   HomeSeer Message Board > HomeSeer > General Discussion Area
General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old September 4th, 2009, 03:27 PM
Richard's Avatar
Richard Richard is offline
Default Status field is unchanged
Using ver. Standard Edition 2.3.0.117
I set up and event to write to status so web page would show a value more accurate than On or OFF
panel dimmed # but now I can not remove it or reset it to ON or OFF
I thought that setting a status displayed value would help define better the activity of device ( maybe even a pending change as a process runs and completes) but could not get this to reflect my configuration.
It reads;
panel dimmed Interior Hallway Downstairs Front Lamp G2 G2 Today 2:19:43 PM
How can I get it to reflect a simple ON & OFF ??
Thanks.
Old September 4th, 2009, 10:06 PM
Rupp's Avatar
Rupp Rupp is online now
Default
It reads;
Thanks.
If you are asking how to set it back to default your can urun this script using the Control link, Immediate Script Command:
&hs.setDeviceString "A1", clear
-Rupp
Old September 4th, 2009, 11:23 PM
Richard's Avatar
Default device still has text based status instead of ON & OFF
Tried that, did not clear device still have "panel dimmed" in status field.
see attached
Old September 5th, 2009, 12:01 AM
Rupp's Avatar
Default
Is another plugin that changes device strings controlling this device?
-Rupp
Old September 5th, 2009, 12:37 AM
Richard's Avatar
Default status field
no just x10 and cm11a device.
the status field "box" in the device action was set to panel dimmed
and as you can see not it is stuck. ??
Old September 5th, 2009, 10:56 AM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Super Seer
Default
You could also try the immediate script, &hs.SetDeviceString "G2", ""
Mike
____________________________________________________________ __________________
HS 2.3.0.19 || Stargate 2.2 | ACRF2 1.0.3226.27426 | VWSCSV 2.2 | Ultrastatus 1.1.3172.37875 | BLRFID 1.0.35.0 | PowerTrigger 1.3 | NetCam 1.1 | ActiveBackup 2.0.0.26 || Scripts: Weather XML | PerfMon | VDGraph || HW: EeeBox | JDS Stargate | NetworX NX-8E | CAV6.6 w ABUS | Slink-e / CDJ | Compose switches, keypads, firewalls | WGL800 | RFXCOM LAN2 | LaCrosse 2310
Old September 5th, 2009, 11:47 AM
nightwalker nightwalker is online now
Default
I've had to reset a device string back to the default a few times for devices I was going to re-use. I've notice that after you reset it, using the "&hs.setDeviceString "A1", clear" command, it sometimes doesn't take effect until you turn the device off and on a few times manually.
Marty
XPpro SP3 /w HS 2.4.0.6
