Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old September 12th, 2009, 02:34 AM
nslmanu nslmanu is offline
Default Launching telnet commands under homeseer : Possible ?
Hello,
I'd like to launch some simple telnet commands under homeseer , but it's really simple as expected.
I don't found any help on the support web site
http://www.homeseer.com/support/home...2/homeseer.htm
I tried to put it in a .bat file , but doesn't work too :
telnet musicserver 9090
player count ?
or other commands
exit
</pre>Do you think it's possible ? with a simple way ?
Thanks a lot ...
Regards
Old September 12th, 2009, 06:49 PM
drozwood90 drozwood90 is offline
Super Seer
Default
I've use a script that I got from the board.
Take a peek around the board.
If you can't find it, I'll look through my scripts directory for you.
--Dan
"There are three kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves."
Old September 13th, 2009, 01:00 PM
Default
The only thing i've found is "how to keep a telnet session open" just it , and after watching, don't found something about executing telnet commands ...
sorry but thanks for your proposition.
Old September 13th, 2009, 03:27 PM
Super Seer
Default
Here you go:
I use this to access ZoomPlayer on another machine from my server.
I hard code the IP and Port, then you just parse out the param object to what you want. Again, this one is designed to just send specific commands to ZoomPlayer.
It is a .vb file, so rename it. Enjoy!
--Dan
Old September 17th, 2009, 04:30 PM
mterry63 mterry63 is online now
Default
Launching telnet would be different than supplying a scripted input to the telnet application after it is launched. Unix supports such input to telnet, but I don't believe MS's windows telnet app supports it. Basically you are just redirecting 'std input'.
That being said you could you Cygwin on your HA server. It's a Unix-on-windows implementation that is easy to use that supports the bash shell.
I've used the unix command 'expect' successfully to script telnet under Cygwin, much more control than simply redirecting std input. It supports branching and other logic.
Old September 18th, 2009, 12:34 AM
Thumbs up
Yes mterry63, i alrready have installed cygwin on my computer ( and it works fine for my netcams plugin scripts ) ... but before using something OUT of hs2, just prefer to know in there is something IN ready to use ...
I agree that if there isn't , cygwin is another way ( a good ) to use telnet with stdin/out.
