Go Back   HomeSeer Message Board > Audio & Video Support > Audio / Video Hardware Plug-ins > Hauppauge Capture (3P)
Hauppauge Capture (3P) Discussions relating to the Hauppauge video capture plugin.
Old October 24th, 2009, 04:37 PM
simonmason simonmason is offline
Default Accessing streaming camera image
I am trying to access my cameras through MainLobby. I have the streaming set to port 2407. This works fine when I navigate through the homeseer menus to the Stream option. However, I just get blank screens when I access http://mypc:2407. I have tried this using the internal IP address and external host name (trying to eliminate the firewall which does have 2407 forwarded). What do I have to put into the browser to go straight to the streaming image? Thanks.
Old October 24th, 2009, 06:38 PM
Pete's Avatar
Pete Pete is online now
Super Seer
Default
I am guessing you are trying to stream the video from another source (not ML) eh?
I believe...and its been a while but you will need to set up a reverse proxy or stream it from the source to see your video outside of your network. IE: set up your firewall to pass your video stream outside of your home network.
Another thing you could try is installing a network camera capture program on your ML server which will live capture/stream network video. This way the source video IP would be the same as your ML server IP?
Base HW & SW: P4 2.97 GHz / 1Gig / MS Server 2003 - creating duplicate server
HS Version Pro 2.4.0.11 pending migration to new computer-Mini-ITX based
HAI OmniPro II X 2 @ FW V3.2D (new 3.3 FW is out?)
Powerline: X-10 & Insteon & UPB (testing) Pending Z-Wave - UPB testing begins with 3 switches for now.
Sound - Current 10 pairs of speakers for HS and music- 6 local subzones -AB8SS- readdressing methodologies / HS control - bought a Russound/KPLs to play with for now.
Old October 24th, 2009, 07:10 PM
Default
I can access my homeseer web site just fine inside and outside the home. I have port 2407 forwarded to the homeseer server. This doesn't explain why I can't access the streaming video from within the home using internal ids?
For example, my homeseer server is 192.168.1.155
Shouldn't I be able to see the streaming video on:
http://192.168.1.155:2407?
When I plug this URL into Windows Media Player it works fine - but I get nothing when I plug this into IE.
Obviously I am missing some required syntax to display the video window on an IE page.
Old October 24th, 2009, 11:23 PM
Pete's Avatar
Super Seer
Default
So is your video source the same IP as your HS or ML Box or is it a different IP?
Old October 24th, 2009, 11:30 PM
Default
It is the same IP.
Old October 25th, 2009, 11:58 AM
Pete's Avatar
Super Seer
Default
If you can see it with WMP then your should also see it in IE. Does it show a box or give you a codec error? Try running same with Firefox.
Old October 26th, 2009, 09:32 PM
bmms bmms is offline
Default
This does not work because the URL you are giving IE is a streaming address - not a web page. If you direct ML to a web page containing the Media Player ActiveX control that directs the stream to "http://192.168.1.155:2407?" it will work.
Bryan
(Config is in my profile)
HTML code is On
