Go Back   HomeSeer Message Board > User Interface Support > Touchscreen Plug-ins > MainLobby (3P)
MainLobby (3P) Discussions related to the MLHSPlugin: MainLobby-HomeSeer Two-Way Communication 3rd party Plug-In for HomeSeer
Old October 25th, 2009, 02:17 PM
simonmason simonmason is offline
Default Fast mode?
Do variables update in fast mode? I am trying to run an automation rule on a plugin variable in Main Lobby but it is not working. I posted on the Cinemar board and they said that it won't work if it is updating in "fast" mode. Is there something I can do to adjust this for this variable? Thanks
Old October 31st, 2009, 01:04 PM
Krumpy's Avatar
Krumpy Krumpy is offline
Super Seer
Default
Depends which version you are using.
I published two beta plugins recently. The first uses fast mode and the second doesn't.
I would do all of my logic in HomeSeer as it is faster.
Old October 31st, 2009, 02:02 PM
Default
I think I have to do this in MainLobby. I storing a decimal number (currency) in Homeseer and I want to display it in MainLobby. Homeseer status variables don't allow decimal values so I am multiplying the number by 100. Then in MainLobby I am dividing by 100 through an automation rule. But it is not working - according to feedback on the Cinemar board because it is using a fast update so the automation rule doesn't run? Thoughts?
Old November 1st, 2009, 09:30 AM
Krumpy's Avatar
Super Seer
Default
You certainly can do this in HS. Probably even easier as you can use VBSCRIPT. Give me what you got in ML and HS and I will tell you what to do.
Old November 1st, 2009, 10:10 AM
Default
It's not at all complicated, I have a scene that allows the kids to track their chores and allowance! For example, the homeseer script keeps track of the allowance and stores the variable as follows:
AnnaAllowance = AnnaAllowance * 100
hs.SetDeviceValue "W47", Ccur(AnnaAllowance)
I am multiplying the amount by 100 because the Homeseer device cannot store a decimal number.
Then I am displaying this value in MainLobby through the plugin. I added an automation rule to MainLobby on this variable to divide it by 100 before displaying it.
Whenever mlhsplugin_w47_value changes value
Then MLServeCmd.MLMath|Divide~{{mlhsplugin_w47_value}}~100
This doesn't work, based on what i have figured out from posting in the forum, because the variable from homeseer is being updated in fast mode and therefore the automation rule does not run on it?
Old November 3rd, 2009, 08:03 PM
Krumpy's Avatar
Super Seer
Default
Why store it as a value? Store it as a string and then you can do whatever you want. Use HS.SetDeviceString instead!
When doing the math, retrieve it and convert it to a integer, do the math, and then store it again as a string. If you need to format it to the appropriate decimal places then use the vb format command.
Old November 3rd, 2009, 10:00 PM
Default
How I display the string in MainLobby? Is it {{mlhsplugin_w47_string}}? Thanks.
Old November 3rd, 2009, 10:40 PM
Krumpy's Avatar
Super Seer
Default
{{mlhsplugin_w47}}
Or if you're using the new plugin:
{{mlhsplugin_name of the device}}
Old November 4th, 2009, 12:11 AM
Default
HTML code is On
