Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Doo Plug-Ins & Scripts > Motion Sensor Plug-In
Motion Sensor Plug-In Discussions relating to the DooMotion plug-in, provided by Jim Doolittle. This plug-in is available from the HomeSeer updater.
Old November 3rd, 2009, 07:18 PM
itanic's Avatar
itanic itanic is offline
Default Privacy Mode
My wife has asked me for an easy way to turn off motion detection in the house during certain times of the day. Is there a way to do this with the plugin without turning off all of homeseer or disabling the plugin altogether?
Regards, Bob
Old November 5th, 2009, 03:46 PM
itanic's Avatar
Default
Trying to disable certain motion sensors using the following
hs.Plugin("DooMotion").GetSensorByName("Patio Motion Sensor").Disabled = True
but it does not seem to be working. Any ideas?
Regards, Bob
Old November 5th, 2009, 06:20 PM
itanic's Avatar
Default
Solved.
Script was correct, but I began by using hs.GetPlugins("DooMotion") which crashed HS program. Rebooted and all seems to work now.
Regards, Bob
Old November 6th, 2009, 05:48 PM
NicolaiL NicolaiL is offline
Default
I'm not quite sure exactly what level of privacy it is you're after?
I would have thought that almost no matter what you disable the PIRs would still record entries to the log file at least (mine are X10 so any signal is blended in with the rest of the X10 devices).
What I have done is to make sure that any actions resulting from PIRs detecting motion results in CAC being fired. That way I have some control over what/when action is taken.
Personally I don't use it for privacy as such, but more to make sure that PIRs don't turn on the bedroom light at night time and so on.
Not sure if this is where you are going with your project?
Old November 6th, 2009, 06:22 PM
itanic's Avatar
Default
Simply put, I'm trying to stop the receipt of any motion/no motion transmission from my motion senors. I have several in the house and use the ACRF plugin to receive signals from them. My wife would like to have the ability to occasionally "turn them off" so that she can walk though the house without the system recording her movements. Disabling the plugin is not that answer as the ACRF still records changes to the underlying devices regardless of the status of the DooMotion plugin. I've started another topic in the ACRF plugin forum to see if there is a way to exclude certain house codes in the plugin using script.
Regards, Bob
HTML code is On
