| General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer. |
November 3rd, 2009, 08:13 PM
sms to Blackberry
hmmm feeling dumb.
trying to set up a simple event to SMS text my Blackberry
set up e-mail with my embarq pop/smtp stuff
set up SMTP server, no pop.... (want no incoming)
turned MAPI off
on event
11/3/2009 5:18:39 PM - Error - Sending email using SMTP: The server rejected the sender address. The server response was: 501 5.5.2 MAIL FROM syntax error
where else can I look ? tain't that hard
Home:
1400 Sq Ft / going Z-wave
(1) RCS-TR60w/ZWB (2) HSM (2) Relay (2) LoVolt (7) 600w (2) 1000w
Hardware:
HP, 64 X2 dual core, 2Gig DDR2
Security:
DSC 1832, 8 Wired, 8 Wireless, 5401, Optex Motion
Software:
HSPro 2.4.0.11| Maestro 2.5.0.19 | Awareness 2.5.0.0 | HVAC 2.5.0.0 | Sprinklers 2.5.0.0 | Music 1.1.0.14 | Weather 1.0.0.4 | Frame 1.0.0.0 | DSC Security .31146 | Weather XML | Onkyo .39724 | BLRfid | Itunes 2.4.0.35 | BitWISE 1.3.0.0
November 3rd, 2009, 09:44 PM
Most internet providers allow you to setup several users.
Try setting up a seperate one of your HS machine and just use your normal internets smtp.
I have found that sometimes the internet providers don't like another smtp host inside there network.
Only problem is you need to have HS check for incoming mail ever so often other wise the internet provider will shut it down because of no pop activity.
It's just a suggestion but works great for my email text messages.
Remember to have FUN....Sonny
HSPro, Stargate, IR Xpander, 4 channel Modulator, Davis weather station, X10, DS-10's, Zwave, Z-Troller, Smartstick, Intermatic, Schlage Link Locks and Trane Zwave thermostat, Home Server, Vista Media Center, ACRF, W800, RFXcom, OS temp sensors, Iphones, Genset, bunches of relays, wires etc
Lots of fun.
November 3rd, 2009, 09:45 PM
Can you send an email to your isp account?
-Rupp
November 4th, 2009, 05:55 PM
Sounds like the "from" email address you configured in Homeseer isn't valid. It most like has to be "from" the same domain as the SMTP server as well.
November 4th, 2009, 06:08 PM
thanks for the suggestions
will try tonight !!
ok... status update....
made new account " ThomasHA@embarqmail.com "
set password
turned on MAPI
error now is ...
11/4/2009 3:34:25 PM - email - Logon Failure for mail system with profile name: ThomasHA@embarqmail.com, Error is: Login has failed
using pop.embarqmail.com
smtp.embarqmail.com
when I try to send from HS...
11/4/2009 3:35:59 PM - email - Mail login successful
11/4/2009 3:38:40 PM - Warning - Timeout waiting for MAPI pending email operation to complete.
gurrrrrr. got to be something dumb
Home:
Hardware:
Security:
Software:
November 5th, 2009, 11:40 AM
Are you sure you need mapi enabled? Do you have a microsoft mail client installed on your Homeseer machine, like Outlook?
November 5th, 2009, 11:49 AM
tryed it both ways as I went along
will turn off tonight
Home:
Hardware:
Security:
Software:
November 5th, 2009, 09:13 PM
Came home tonight and my blackberry told me someone dis-armed the system
didn't do anything..... Thanks for all the support
got a few errors in log, but will turn off the MAPI and see what happens
Home:
Hardware:
Security:
Software:
November 17th, 2009, 11:40 AM
Got it up and running....
Thanks for all the guideance
MAPI = no
smpt and pop needed the port numbers added ( :587 )
last and hardest error was a bad return to address
Home:
Hardware:
Security:
Software:
| Thread Tools |
| Display Modes |
Linear Mode
