Go Back   HomeSeer Message Board > HomeSeer > General Discussion Area
General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old November 4th, 2009, 11:23 PM
GatorEye GatorEye is offline
Seer Plus
Default Pressure Mat On Stairs
I was hoping to be able to have access to under the stairs in my new house. Unfortunately the design did not allow that to be possible. I was considering a pressure mat on the first step for use down the road (turning the light on perhaps), but I'm wondering how I would do that if I wouldn't have access to any wiring connected to it once the walls are closed up.
Would I just buy one and put it on the step and have them put the padding and carpet right over top of it?
Do they work well? I figured it would work better than a motion sensor that would trip every time someone walks past the stairs rather than up/down the stairs.
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Old November 4th, 2009, 11:54 PM
sdanks's Avatar
sdanks sdanks is offline
Default
I am a big fan of light beams. I would put in a infrared light beam across the bottom of the stairs and a motion sensor at the top. Then someone would have to step on the bottom stair to trip the beam, but just approaching the top of the stairs would be enough to light them up. I'm thinking safety. I put those recessed louvered lights that shine down on the stairs on my stairway so it would not blind us at night. You know, the ones that look like theater lights? We didnt get to close on the house, so someone else is enjoying them right now, but that was the idea anyway.
A computer's attention span is as long
as it's powercord.
Old November 9th, 2009, 02:49 PM
MichaelD MichaelD is offline
Default
Thats exactly how to fit one, but I'd put in two in series, in case anyone runs up the stairs two at a time. Or maybe more if you will want to know which direction people were heading.
I've put two in series on my stairs and they work extremely well, I just wasn't able to find a way to fit a motion sensor that worked so that the upstairs lights came on before you reached the top step, and didn't trigger every time someone walked past. Pretty much the same problem you're wanting to address.
Old November 9th, 2009, 10:16 PM
Seer Plus
Default
How are you able to access it once it is covered over? How did you get the wiring out of it into something that HS can interface with?
Old November 9th, 2009, 10:28 PM
Rupp's Avatar
Rupp Rupp is offline
Default
You should search on this board for Pulsor as these are professional quality and work really well.
-Rupp
Old November 10th, 2009, 11:15 AM
buvens buvens is offline
Thumbs up
For something "quick and Dirty" the pressure mats Harbor Freight sells for around $10 work great when connected to DS-10's and placed under a throw rug or mat.
I use them all around the house and at the botom of the steps to turn lights on.
They are not as fancy as the others but for the last couple of years, ever since I knew they had them, It is a nice cost effective solution.
Remember to have FUN....Sonny
HSPro, Stargate, IR Xpander, 4 channel Modulator, Davis weather station, X10, DS-10's, Zwave, Z-Troller, Smartstick, Intermatic, Schlage Link Locks and Trane Zwave thermostat, Home Server, Vista Media Center, ACRF, W800, RFXcom, OS temp sensors, Iphones, Genset, bunches of relays, wires etc
Lots of fun.
Old November 10th, 2009, 06:27 PM
Default
I ran the wire under the stairs and into an ocelot secu16, but you could use the gameport plug-in, or DS10s, the pressure mat works like a simple push-button switch, so you have plenty of options.
The pressure mats I used were pretty cheap, but they have lasted 2-3 years so far without any problems.
