Go Back   HomeSeer Message Board > HomeSeer > General Discussion Area
General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old November 5th, 2009, 02:30 AM
mlucas mlucas is offline
Post Tank Level Monitoring
Hello All,
Looking for some suggestions on monitoring the level in our oil tank from HomeSeer. We also have an exterior water well and cistern which we would like to monitor the levels of. Wireless would be prefered.
Any suggestions?
Michael
Old November 5th, 2009, 08:05 AM
bmora's Avatar
bmora bmora is offline
Default
How I do it is by putting magnets on top of the fill indicator of the tank and using a DS10A so when the fill indicator falls below say 1/4 tank the DS10A will trip when the magnet on top of the fill indicator gets down there. Has worked great over the past few years.
Old November 5th, 2009, 12:25 PM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
Default
Ultrasonic sensors are good for measuring liquid tank levels http://board.homeseer.com/showthread.php?t=136825. The packaging is a DIY project for the low-end sensors such as the EZ1 that I referenced. Also need to be concerned about any electronics around petroleum fumes. To achieve wireless you would need RS-232/IP adapter, but then you still need a source of power.
Old November 5th, 2009, 12:43 PM
jon00's Avatar
jon00 jon00 is offline
Default
You might want to do some research to see if you can get the following products in the US (these are for the UK)
http://www.tankdepot.co.uk/shop/32_4...uge/index.html
http://www.tankdepot.co.uk/shop/32_3...ge/index.html?
They are probably readable via the RFXCOM receivers and plugin but if not I'm sure they could be added.
Jon
Old November 5th, 2009, 10:11 PM
Post
Thank you all for your suggestions. Lots to review.
I also found this thread which as additional ideas:
http://board.homeseer.com/showthread.php?t=112659
Michael
