| General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer. |
November 5th, 2009, 09:32 PM
How to cancel timer?
If I set a device to turn on with a delay, such as:
Basement Wiring Closet Sleep On Delay: 00:10:00
and let's say 5 minutes has gone by and I want to stop this Device from triggering, how do I stop it?
Thanks.
November 5th, 2009, 09:52 PM
Super Seer
Can't you just delete the delayed event?
HSPro 2.4.0.11 || Plug-ins: Stargate | ACRF2 | VWSCSV | UltraStatus | BLRFID | PowerTrigger | NetCam | ActiveBackup | UPB | mcsXap | UltraMon | Russound
Scripts: Weather XML | PerfMon | VDGraph | ImageBuilder
HW: EeeBox | JDS Stargate | NetworX NX-8E | CAV6.6 w ABUS | Slink-e / CDJ | Compose switches, keypads, firewalls | WGL800 | RFXCOM LAN2 | Quatech QSE100D | LaCrosse 2310
November 6th, 2009, 06:52 AM
The event is one that I use every night. I don't create it dynamically through a script - it is created through the web interface and I invoke it when a certain time is reached - or manually. The logic is:
We tell homeseer to put the house to sleep (ie. lights off, thermostat setback, alarm, etc.)
I do this by setting a status called sleep to on with a delay of 10 minutes - gives us time to get up the stairs, etc.
But what if I come back down stairs looking for something, the 10 minute timer is still running and I know it is going to set sleep to on, and I want to stop that process.
If I delete the event then I would have to recreate it to run it again? Maybe I am not fully understanding your suggestion?
Thanks.
November 6th, 2009, 07:07 AM
Try and check to see if the 'Remove Delayed Event Trigger' works from the action page (then put the house to sleep event as the one you wish to remove), I think it will do what you are asking.
November 6th, 2009, 08:32 AM
I think you can do it this way (as mrhappy said). Set up the actions in your original sleep status event in this order:
1. Remove Delayed Event Trigger for <your sleep status event>
2. Run the action that sets the sleep status, Delay: 00:10:00
This way, if you run the sleep event the first time, it runs as usual with a 10 minute delay (it simply skips the "remove delayed event trigger" because there isn't one).
If you trigger it a second time, it will cancel the first one, and reset the delay to 10 minutes.
The only issue you might have with this is that you cant actually stop the event, only delay it as many times as you want. You could create another event to actually stop the sleep status event (action would be step #1 above without the #2).
=caduceus=
November 6th, 2009, 09:12 AM
Super Seer
When you say you want to 'stop the process' do you mean you want to tell it to resume from where you stopped it, rather than start it over again? I don't know how to do that. As others have noted, if you just want to start the timer over, that should be fairly easy to set up.
On the other hand, if you put the house to sleep gradually over the 10 minutes (I didn't think that was what you are doing, but maybe I didn't understand), then it will depend on what those things are and the effect of repeating a sequence that was previously partially done has on each device. In our house our sleep function is in two steps, so I have added a 'reverse' function that will undo all the things the sleep function does in case we want to reset it and start over.
Note added: Just to be clear, when you execute an event to set a status on with a 10 min delay, HS creates a new event, with a time based trigger that is 10 min in the future. It is that event that I was referring to when I suggested deleting the delayed event.
Reason: add clarification
November 6th, 2009, 10:21 AM
Interesting problem that I have ran into a few times...
The way I usually try to get around it is by using different logic.
What ever currently triggers "go to sleep event" occurs and sets a status device named "ready to sleep".
Then create an event that if no motion in said room for at least 10 minutes and ready to sleep is on... then procede with sleep mode actions... turning off lights etc.
November 8th, 2009, 11:51 AM
It is the actual event that I sometimes want to stop. The only way I can think of to achieve this is to write two scripts?
| Thread Tools |
| Display Modes |
Hybrid Mode
