Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old November 12th, 2009, 06:27 AM
mmcalli mmcalli is offline
Default How to edit floor and/or room names?
I made a mistake while naming rooms and/or floors. Where can I edit these?
Mark
Old November 12th, 2009, 06:32 AM
Moskus's Avatar
Moskus Moskus is offline
Default
I think you have to edit all the devices and set them to a new floor/room. When a floor/room is not used, it is removed (isn't it?).
Old November 12th, 2009, 09:41 AM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Super Seer
Default
I assume by 'Room' and 'Floor' you are referring to 'Location' and 'Location 2'. (At least that's how my system displays them.)
You should be able to select the location name you want to change in one of the drop down boxes at the top of the Devices page. That will list all the devices with that location. Put a check mark next to the ones that are incorrect, and then select 'Change selected device(s) location' in the drop down at the bottom of the page. Either select the correct location or enter a new location and click on 'Go'.
HSPro 2.4.0.11 || Plug-ins: Stargate | ACRF2 | VWSCSV | UltraStatus | BLRFID | PowerTrigger | NetCam | ActiveBackup | UPB | mcsXap | UltraMon | Russound
Scripts: Weather XML | PerfMon | VDGraph | ImageBuilder
HW:
EeeBox | JDS Stargate | NetworX NX-8E | CAV6.6 w ABUS | Slink-e / CDJ | Compose switches, keypads, firewalls | WGL800 | RFXCOM LAN2 | Quatech QSE100D | LaCrosse 2310
Old November 12th, 2009, 12:47 PM
Default
If it does in fact automatically delete unused named locations, then that's the ticket. I just don't want to have multiple unused items in the list to cause confusion. (eg. LVRoom, LivingRoom, Living Room).
Guess I'll have to try it and see. Thanks,
Mark
Old November 12th, 2009, 06:13 PM
Super Seer
Default
Unused names are deleted in my experience.
HW:
Old November 13th, 2009, 05:13 AM
Default
Mosjus and Mike,
Thanks, I tried moving the devices into the new room and sure enough--the old empty room name dissapeared.
