Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old November 12th, 2009, 10:41 AM
Twisted Twisted is offline
Talking HS2 Remote control access problem - sloved :)
I have an opportunity for someone to shine. It appears that when HS2 is installed, that it sets up DCOM for local access to the HomeSeer2.application only. I would like to have remote client access to HS2. Someone who understands the install process could write an executable to enable and disable remote access on the HS2 server, or alternately to do the same function for client systems. Proof of concept. Write a simple VBS to access HomeSeer2.application locally, test it and store the script on a network share. On a network linked PC, using VPC generate two hosted copies of WinXP in unregistered (trialware) mode, link to the HS2 server and the network share containing the VBS. Execute the VBS on either or both of the hosted OSs. The scripts should fail to link to the HS2 server. Install HS2 in trialware mode, (OOB install) is all that is required. Then run the VBS again, the one that executes on the VPC containing OOBI HS2 will run, and the other will not connect to the HS2 server. Note: 1) The HS2 server name must replace the localhost entry in the VBS for it to connect. 2) the server name entry in the CreatObject is useless until the HS2 server recognizes remote access. 3) The IP addresses and names for the three machines entered in the C:\WINXP\system32\drivers\etc\hosts files of all the machines, makes the code more readable, and easier to modify. Sample code (no error checking), and sample host file enteries follow.
Dim hs,hsi
Set hsi = createobject("HomeSeer2.application", "localhost")
hsi.SetHost "localhost"
Set hs = hsi.GetHSRef
hs.speak "Hello World"
hosts file entries
# HS2 server
192.168.x.x dogwood
# VPC 1
192.168.x.x boxwood
# VPC 2
192.168.x.x redwood
Old November 12th, 2009, 10:43 AM
Rupp's Avatar
Rupp Rupp is online now
Default
If you want access to the client system install the speaker app and you can use the same script to access the remote system.
-Rupp
Old November 12th, 2009, 10:58 AM
Default
Well, I still get the same error message, can't create the object. I want to use more than just the speaker, EXECX10, and other commands. It's a runtime error, the remote object is not visible. (access denied)
Old November 12th, 2009, 11:11 AM
Rupp's Avatar
Default
You have to use the remote ipaddress ie
Set hsi = CreateObject("HomeSeer2.application")
hsi.SetHost("remoteipaddress:8742")
rval = hsi.Connect("username", "password")
If rval <> "" Then
MsgBox(rval)
End If
hs.speak("Hello World")
-Rupp
Old November 12th, 2009, 11:16 AM
Default
The error occurs trying to create the object from the remote machine. If the object is available locally, then the link to the remote HS server host is fine. The error occurs at run time trying to create the object, access denied). If you use dcomcnfg.exe and look in the Component services / computers / My Computer / DCOM Config, and HomeSeer2.&clsString is listed then the code that you provided will work without a problem. If it's not listed, then the server parm of the createobject must be used to direct the command to the remote system. If the object on the remote system is setup as local access only, the remote system will refuse to grant permission to create the object. By installing the HS2 application on the local machine, a local object is available to use, once that is done, it can be redirected to the remote system, and connected without a problem. This works, but, it is not a very elegant solution, it maybe a little fuzzy in the licencing department,(installing software but not using it). I submitted a help desk ticket on the acceptable use of the software. It appears that multi computer links is a little too far outside the box for what was origionally the design scope for the product. For me this is not the puzzle, only one piece. The other pieces include computer vision(where are my car keys), robotics(well, bring them to me), face recognition(find me in the crowd at the party), and face tracking(head nods and shakes in response to questions). You may have thought that home automation was an expensive hobby, but thirty years in computers, has shown me just what wetware can do to software, firmware, and hardware.
Old November 13th, 2009, 10:00 AM
Default
If the help desk doesn't lose the ticket, I will post the results, a mod, a patch, a feature, an enhancement, a change, or acceptable use, whatever it is called today.
Old November 18th, 2009, 05:32 PM
Default
For anyone planning to run HS2 control scripts on a system other than the HS2 server. An example, the HS2 server is in the basement with its bundle of controls and wires purring merrily along. You are in your second floor den at your computer, on that computer you have installed the remote speaker client, so that you can use the network rather than run a microphone cable to the basement. So far so good, you have a weather station, or some other software running on that computer, and you would like to have HS2 respond to some event that happens on the den computer. You can run a script on the den computer, using the den computers resources that will act the same as running the script on the HS2 server. This is how its done.
Install HS2 on the den computer. That is it, of course you can not run the copy of HS2 on the den computer, but you don't need to run it, ever. The registry entries done by the install is all that's required. Now it is time to write the script, pick your language, as long as it supports "CreateObject" it can be used. You need a preamble on your script, an example follows, then just write the script as if were to run on the HS2 server. You will have access to all HS2 functions and features.
This example is in VBScript because that language has support built into windows.
Dim hs,hsi
Set hsi = createobject("HomeSeer2.application", "HS2host")
hsi.SetHost "HS2host"
Where "HS2host" is the name of the HS2 server running in the basement, as it appears in My Network Places (Ref. WinXP). Follow this preamble with your script. As to the second installed copy of HS2. From the help desk, in response to a question about the 'acceptable use of software' addressing the installation of mutiple copies of HS2 on different systems, I received this reply. The key word in this reply is 'used'.
I'm not sure what you are stating here but as long as HomeSeer is only used on one server you are within the license agreement
Greg Hughes
Old November 18th, 2009, 06:05 PM
Rupp's Avatar
Default
Here's one of Richs posts for a while back explaining the same concept.
http://board.homeseer.com/showpost.p...7&postcount=14
-Rupp
Tags
remote access, remote control, remoting
