Go Back   HomeSeer Message Board > User Interface Support > Touchscreen Plug-ins > MainLobby (3P)
MainLobby (3P) Discussions related to the MLHSPlugin: MainLobby-HomeSeer Two-Way Communication 3rd party Plug-In for HomeSeer
Old November 15th, 2009, 08:10 AM
simonmason simonmason is offline
Default Running MainLobby on another PC
I wanted to check this before I did it. When I look at the documentation it appears that I can specify an IP address or host name in the MainLobby side of the plugin and therefore run MainLobby on a different PC than Homeseer? Is all that is needed? Thanks.
Old November 15th, 2009, 08:26 AM
sonypoolplr sonypoolplr is offline
Default
Yes, you can have the MLServer side of Mainlobby on one computer and Homeseer on another.
So you need the Mlserver and the plugin on both ends loaded.
HTH
Old November 17th, 2009, 08:14 PM
Krumpy's Avatar
Krumpy Krumpy is offline
Super Seer
Default
One trick.. Make sure that you have the latest MSWinsck.DLL on both systems.
Old November 18th, 2009, 07:48 AM
Default
Everything seemed to work after the move so I am not going to mess with anything!
Old November 21st, 2009, 09:47 AM
Krumpy's Avatar
Super Seer
Default
Just read the enclosed thead if you get MLHSPlugin to disable itself.
This is all because of the not having an updated Microsoft Winsock control.. Not my issue.
HTML code is On
