| General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer. |
November 16th, 2009, 02:32 PM
Super Seer
install 2 x ECM-1240 and plugins
yeah i called them and they are going to email me a link to updated pricing..
basically it is
$199 for first unit
$129 for second unit..
but for the peeps up here running this.... with hs plugin..
how do you go about connecting 2 of these puppies up? anyone do that with the plugin yet?
I am going to go 2 in about a week....
I want to monitor
main
dryer
a/c
remaining misc circuits in house....
doing 2 units will get m
main + 6 circuits + 7 circuits from second unit...
also im gonna have to hook these up via serial?
i see a zigbee adapter or ethernet?
ok so since i have not ordered anything yet.. what is the best way to hookup 2 of these?
Homeseer: Upgraded path 2.3.0.19==> 2.4.0.6==> 2.4.0.11
Blade - BLBackup|BLDeviceMatrix|BLFloorplan|BLIcon|BLPlugins|BLRain8 x10|BLUPS|BLWeather
Jon00 - BuildPage v2|gcalc|ini editor|horoscope|Simple downloads
Misc - AC-RF2 Processor|CONCORD Plug-In|DVD Collection|Maintenance|RFXCOM|SmartHome PowerLinc USB|Rover|tccal|UltraLog|US Weather Warnings|Weather Scripts|WeatherXML|z-wave thermostat
November 16th, 2009, 04:04 PM
Which plugin are you using?
The free tenHsEcm12xx plugin supports two ECMs as follows:
1 serial port and 1 ethernet
2 ethernet
So, make sure one of them can be connected via ethernet.
tenholde
November 16th, 2009, 05:56 PM
Super Seer
2 ethernet
tenholde
ok.. so then I need to make sure to get the ethernet versions... maybe if not too much.. get both of them as ethernet...
November 16th, 2009, 07:18 PM
If it is within your budget, I always advise getting the radio built into the ECM as it keeps your options open going forward.
You need at least one wirelessly talking to an etherbee connected to your network.
tenholde
November 16th, 2009, 10:07 PM
Super Seer
tenholde
oh so i also need a etherbee then..
so if i got 2 units with built in wireless and a etherbee.. then i dont need to worry about serial ports and running serial cables then???
that would be nice...
November 17th, 2009, 09:43 AM
That's what I'd recommend. Working great for me. I test with one serial and one ethernet, but revert back to running both through the etherbee most of the time. Never had a problem.
tenholde
November 17th, 2009, 10:54 AM
Super Seer
can you point me in what I would need? sorry but i have really no clue on this end...
http://www.brultech.com/price2ecm1240.html
I was hoping to do just the serial and ethernet... when you say this can be done.. you are saying one as serial and the other as ethernet, the ethernet one is cat5 based non wireless right?
so if I get Package B/200 with E1 expansion..
that will give me
both with serial (rs232) and one with etherport (rs232)
that would do it then that way right?
November 17th, 2009, 03:39 PM
The scenario of one ECM with a Zigbee radio talking to and Etherbee (Etherbee wired via Cat5 to your router) and another ECM without radio connected via a serial cable works very well.
That would be:
A+/200 for 243.00
E1 for 129.95
Etherbee for 139.38
With that configuration, I can help you get up and running quickly and it is probably the cheapest for you.
November 17th, 2009, 07:32 PM
Super Seer
That would be:
A+/200 for 243.00
E1 for 129.95
Etherbee for 139.38
umm yeah that isnt in the budget... i figured i would go with 2 so i could have alot done but not at $600... I was hoping to get by at no more than $400!!!!!
im gonna have to weigh out what to do...
can I just do 1 via serial then? im gonna presume yes....
November 17th, 2009, 11:13 PM
Start with one serial and you can always add the second later.
tenholde
November 17th, 2009, 11:23 PM
Super Seer
tenholde
that is what im gonna do..
so 1 serial and that is it... without zbee ....
| Thread Tools |
| Display Modes |
Linear Mode
