Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old November 17th, 2009, 02:35 AM
twa8000 twa8000 is offline
Default On-Open-Motion & Off-Closed-No Motion
I have a Aeon D/W Sensor and it always reports either..
On-Open-Motion or Off-Closed-No Motion
I want to change it to just Open or Closed...
I went into "edit value-status" and i was able to change it.. but once the sensor was changed.. it went back to On-Open-Motion & Off-Closed-No Motion...
I was successfuly in adding graphics to the status.. but i still cant not change the text... any ideas?
-Tom-
Old November 17th, 2009, 10:56 AM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Super Seer
Default
Is the sensor linked to HS through a plug-in?
Mike
____________________________________________________________ __________________
HS 2.3.0.19 || Stargate 2.2 | ACRF2 1.0.3226.27426 | VWSCSV 2.2 | Ultrastatus 1.1.3172.37875 | BLRFID 1.0.35.0 | PowerTrigger 1.3 | NetCam 1.1 | ActiveBackup 2.0.0.26 || Scripts: Weather XML | PerfMon | VDGraph || HW: EeeBox | JDS Stargate | NetworX NX-8E | CAV6.6 w ABUS | Slink-e / CDJ | Compose switches, keypads, firewalls | WGL800 | RFXCOM LAN2 | LaCrosse 2310
Old November 18th, 2009, 03:44 AM
Default
No,.. Just like any other z-wave device.. import it from the ztroller.. rescanned it and optimized it
-Tom-
Old November 18th, 2009, 11:33 AM
Super Seer
Default
You might get more response in the Z-wave forum.
I don't use Z-wave, so I have no specific knowledge. You could look at the UltraStatus plug-in.
Mike
Old November 24th, 2009, 09:57 AM
Sleepy81 Sleepy81 is offline
Default
How did you get it to report to HomeSeer??
I have the same sensor, but I can't get it to report anything other than battery status. It always says No Motion...
The firm I bought it from claimed that I had to assosiate it to another physical Z-wave device (like a on-off switch) and then set up HomeSeer to report the status of the sensor (open/closed) based on the on-off switches status....
I have HS 2.0.4.1 and used a ZTH200+ ZCU201 to add everything to my network. However recently I have been using a Aeon Labs Z-stick, but I just transfered the old network (ZTH200) over to the Z-stick. Could that be the problem? Will the Aeon W/D sensor work if I add it to the network using the Z-stick instead?
Old November 24th, 2009, 11:01 AM
Rupp's Avatar
Rupp Rupp is offline
Default
Did you try associating it with HomeSeer?
-Rupp
Old November 24th, 2009, 03:04 PM
Default
I tried to do that the other day, but still no go.
But today I thought I'd try to add it to the Z-stick. But I could not get the Z-stick into the "add/include" mode. (When I hit the button, it glowed blue for about 3 sec, but then turned off again... No slow blinking like the manual says...)
So I reset the Z-stick to factory presets, and then used my ZTH200 to feed the z-stick with my Z-wave network settings, trying to "salvage" the network... This is basicly what I did the first time I got my Z-stick. However to my surprise, the Aeon Labs D/W sensor now worked!
I got 4 devices from the sensor (root device, Binary sensor (open/closed), battery sensor, and something called alarm sensor.) I am unsure what the alarm sensor does, but I'm guessing ot triggers if somebody tampers with the physical sensor itself. Anybody know?
Anyways, now it's working perfectly!
Now, after I installed my network again, my HSM100 have stopped reporting motion (reports constant motion, all the time..), so I'm off to try an fix that without breaking something else!
Old November 24th, 2009, 04:53 PM
Rick Tinker's Avatar
Rick Tinker Rick Tinker is offline
HS Logo
Please see this post:
http://board.homeseer.com/showpost.p...&postcount=266
Rick Tinker (a.k.a. "Tink")
HomeSeer Technologies
Old November 25th, 2009, 01:54 PM
Default
Yes the alarm sensor is for if someone rips the sensor off of the door/window/wall...
Old November 25th, 2009, 02:06 PM
Default
Hee hee - I love it.
Old November 30th, 2009, 12:35 PM
HS Logo
OK - if you have an Aeon Labs door/window sensor that reports that it's manufacturer is Intel, then that device is too early for me to trust it working properly. I would see if Aeon will replace it with a more current/production unit. We are in the process of adding Aeon Labs' contact information to the list of manufacturers on the Returns link of the support page at our website. If you do not see it there in a couple of days, contact Rich or Mark and they can get you contact information.
If you have one that says it is Aeon Labs, but the sensor says "On-Opened-Motion" for example instead of "Opened", then let me know the product type and product ID and I can probably get that supported by HomeSeer to use the proper labels. (The only issue is the labels - all other functionality is the same.)
