Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
Old November 20th, 2009, 04:52 PM
neutron neutron is offline
Default Help with Conditional events
I am having trouble using conditional events, I have a sensor hooked up to my GC100 that senses if the satelite receiver is powered on or off, then if I want to turn on the power for the receiver I first need to check that the receiver is off using that sensor, and if it is off send the power ir signal, if it's already on it shouldn't do anything.
When I check the GC100 Log, as the receiver goes on and off the device Bell Power Sensor gets set to 1 and 0, and the device shows on or off accordingly.
I have setup 2 manually triggered with conditions events (Sat Off and Sat On) that when trigered runs the events Bell Power Off or Bell Power On which check to see the status of the sensor then depending on the status will send the Power IR command.
I have attached a screenshot of the events, when I run the events The log says "Delayed event execution skipped, the conditions applied were not met: testing:Bell Power On" (or Off)
I don't see where I'm going wrong here, can somebody please help?
Thanks!!!!
Scott
Neutron Computers and Home Entertainment
Old November 20th, 2009, 07:13 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Super Seer
Default
I think you may have the conditions reversed.
HSPro 2.4.0.11 || Plug-ins: Stargate | ACRF2 | VWSCSV | UltraStatus | BLRFID | PowerTrigger | NetCam | ActiveBackup | UPB | mcsXap | UltraMon | Russound
Scripts: Weather XML | PerfMon | VDGraph | ImageBuilder
HW:
EeeBox | JDS Stargate | NetworX NX-8E | CAV6.6 w ABUS | Slink-e / CDJ | Compose switches, keypads, firewalls | WGL800 | RFXCOM LAN2 | Quatech QSE100D | LaCrosse 2310
Old November 20th, 2009, 07:20 PM
Default
Actually the sensor on the GC100 is reversed, it shows off when the device is on, and on when the device is off, sorry I should have mentioned that. (and I tried it both ways just to make sure too )
Scott
Old November 20th, 2009, 10:02 PM
Super Seer
Default
I don't see any delayed actions, so I'm having trouble interpreting the error message. Am I missing something else?
HW:
Old November 20th, 2009, 10:06 PM
Super Seer
Default
Two more questions. You indicated values of 0 and 1. Those are not standard On and Off values in X10 land. Could it be that the test needs to be run on device value? Or does it need to test the actual value of the status integer?
HW:
Old November 21st, 2009, 09:19 AM
Default
Well, in the GC100 log it switches the value between 1 and 0, The only options it gives me for that device is `On `Off or and `Any Value, there isn't anything else I can select.
Scott
