| HomeSeer HS2™ Specific General discussion about HomeSeer HS2. |
November 22nd, 2009, 09:04 PM
Viewer
How to transfer to a new PC
I'm looking for the best way to move HS2 from my old PC to my new one. Does anyone know if the following steps will work?
Old PC: Windows XP Professional 32-bit
New PC: Windows 7 Ultimate 64-bit
- In the HomeSeer interface on the old PC, go to File, Save As and save my configuration data to the current or a new .mdb file.
- Shut down HomeSeer (or stop the HomeSeer service) on the old PC.
- Install HS2 on mt new PC.
- Copy the .mdb file from the old PC to the new one.
- Start HS2 on the new PC then use File, Open to open the old .mdb file.
- Test, test, test, and test again.
- Uninstall HS2 from old PC.
Will this work?
Thanks in advance.
November 22nd, 2009, 11:35 PM
Location: Troutdale, Oregon (go to Portland, head east)
~Bill
November 23rd, 2009, 01:53 PM
Viewer
Thank you
Thanks for your response! That was exactly what I was looking for.
Honestly, I DID try searching the How-To board first.
November 24th, 2009, 12:45 PM
How to Move just device file
I am doing a similar move, but only want to copy over my devices. What is the file name I need to copy?
I have been changing jobs and raising two teenage daughters on my own and haven't touched HS in awhile. I know I had some issues when I last used it, so I want to upgrade my pc and start over with a fresh install. But I want to be able to copy over the devices file so I don't have to reenter them. Everything else I am ok with starting from scratch - because it will get rid of some of my old mistakes.
November 24th, 2009, 12:57 PM
From the web browser hit the Setup tab.
Here is mine: Current Configuration File: D:\Program Files\Homeseer 2\config\home.mdb
~Bill
November 24th, 2009, 01:01 PM
I didn't realize the devices were separated like that, isn't the mdb file pretty much everything, except IR codes?
Marty
XPpro SP3 /w HS 2.4.0.6
November 24th, 2009, 01:17 PM
For devices only copy the MDB file above then delete out your events.
~Bill
November 24th, 2009, 01:53 PM
oh, you learn something everyday. Thanks for the response.
Marty
| Thread Tools |
| Display Modes |
Linear Mode
