Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Doo Plug-Ins & Scripts > DooNetwork
DooNetwork For Jim DooLittle's DooNetwork plug-in.
Old November 23rd, 2009, 03:56 PM
Msekelsky's Avatar
Msekelsky Msekelsky is offline
Default I can't get wake on lan to work. What am I missing?
The error is:
MAC address of Network Study Computer could not be determined so Wake Up cannot be performed
Using DooNetwork 2.3.2, HS 2.4.01. PC is running Win 7 64 bit. Wake on lan is setup on the PC. When I use "retrieve mac address" in DN device setup it does grab the mac address and I have also run ipconfig and verfied that the address is correct.
Am I missing something simple (I hope)?
--Mark
HS Pro 2.4/Win XP Pro
Plugins: ACRF2/ActiveBackup/DooMotion/DooStat/DooMenuBar/Homevision/iAutomate/HSTV/jvCaddx/Message Server/Web Wrapper
http://sekelsky.homeip.net:81
Old November 23rd, 2009, 05:03 PM
Wadenut's Avatar
Wadenut Wadenut is offline
Super Seer
Default
WOL needs to be enabled in the BIOS of the target machine. Possibly also in the properties for the LAN card under Windows.
There are a number of free utilities out there that will help you determine whether or not you're successful.
I have one machine that simply refuses to respond to WOL (HP media center m7680). Hopefully this isn't your problem.
Automate everything, modify the rest... but remember... For every action, there is an equal and unexpected reaction.
Old November 23rd, 2009, 05:14 PM
Msekelsky's Avatar
Default
I just checked the BIOS and it is set. Wake is enabled in the adapter. I even get the error if the pC is awake which is odd (to me) as DN has no trouble grabbing the mac when I am in setup
--Mark
Old November 23rd, 2009, 05:32 PM
Wadenut's Avatar
Super Seer
Default
In my case, I spent several hours with HP tech support, on several occasions. The last time the technician (and I use the term loosely) actually tried to tell me "this only works wirelessly". I told him that was bull-puckey (which it is) and he hung up on me. The BIOS suggests WOL should work, but no-one, judging from the chit-chat on the web, has ever been successful with this particular machine. The motherboard simply isn't wired for WOL.
Before you drive yourself crazy, as I did, try one of the free apps outside HS, then deal with the plugin once you know the hardware responds.
Old November 23rd, 2009, 07:55 PM
Msekelsky's Avatar
Default
I found a little utility and it was able to wake the PC so at least I know that my PC is wakeable.
--Mark
Old November 23rd, 2009, 07:58 PM
Wadenut's Avatar
Super Seer
Thumbs up
We now return you to the regularly scheduled plugin.
Old November 23rd, 2009, 08:00 PM
Msekelsky's Avatar
Default
--Mark
Old November 30th, 2009, 10:27 AM
Jim Doolittle's Avatar
Jim Doolittle Jim Doolittle is offline
DooSeer
Default
Software implementation of WOL is rather easy once hardware and permissions are set up. I am not sure what I need to do to adresss the inability of DN to perform a WOL. It seems to have worked rather well for most. However, I suppose there could be Windows Updates that change things. If so, more users would be reporting problems.
Jim Doolittle
My Twitter
My Hardware & Software
