Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Doo Plug-Ins & Scripts > DooCPUMonitor
DooCPUMonitor For Jim Doolittle's CPU Monitor plug-in.
Old November 24th, 2009, 12:02 PM
hec1152 hec1152 is offline
Default Warning Message about Status Property
I'm getting the following (warnings) when DooCPU Monitor starts up. I have the "Disable Obsolete API procedure warning messages" set to YES, so I don't know why they are appearing if they are only warnings.
11/24/2009 9:40:02 AM ~!~DooCPU Monitor Info~!~Register callback completed
11/24/2009 9:40:02 AM ~!~Plug-In~!~Initializing Plug-in: DooCPU Monitor
11/24/2009 9:40:02 AM ~!~Warning~!~'status' property on device DooCPU Monitor System CPU Usage was accessed - this property has been deprecated and should not be used.
11/24/2009 9:40:02 AM ~!~Warning~!~'status' property on device DooCPU Monitor System Available Memory was accessed - this property has been deprecated and should not be used.
11/24/2009 9:40:02 AM ~!~Warning~!~'status' property on device DooCPU Monitor HomeSeer CPU Usage was accessed - this property has been deprecated and should not be used.
11/24/2009 9:40:02 AM ~!~Warning~!~'status' property on device DooCPU Monitor HomeSeer Memory Usage was accessed - this property has been deprecated and should not be used.
11/24/2009 9:40:02 AM ~!~Warning~!~'status' property on device DooCPU Monitor HomeSeer Thread Count was accessed - this property has been deprecated and should not be used.
11/24/2009 9:40:10 AM ~!~Plug-In~!~Finished initializing plug-in DooCPU Monitor
Thanks in advance for any advice.
HEC
Old November 24th, 2009, 12:04 PM
Rupp's Avatar
Rupp Rupp is online now
Default
This is simply a warning and can be ignored until Jim gets time to make the change to the plugin.
-Rupp
Old November 24th, 2009, 12:15 PM
Default
Ok. I appreciate the quick response.
HEC
Old November 30th, 2009, 11:15 AM
Jim Doolittle's Avatar
Jim Doolittle Jim Doolittle is offline
DooSeer
Default
I will provide a fix by the end of the week.
Jim Doolittle
My Twitter
My Hardware & Software
Old November 30th, 2009, 08:12 PM
Default
There's no hurrry. I now know to ignor these messages as they are benign. Not worth wasting any of your time on it. Thanks for the response.
HEC
Old November 30th, 2009, 09:14 PM
DooSeer
Default
I need to fix it per HST's request anyway. I can see where they want to move forward. I actually had a heads up a few weeks back and corrected the problem in the source code. Even though I have simplified the publishing of a new build, the publishing part tends to be more tedious than changing the code.
Jim Doolittle
My Twitter
