| RFRemote For Jim Doolittle's UnDooly named RFRemote plug-in. |
November 24th, 2009, 12:10 PM
Warning Message
I'm cleaning up error messages and, among others, noted that the following warning message is not surpressed by the Disable setting in Setup.
11/24/2009 9:40:26 AM ~!~RFRemote startup~!~Initializing RFRemote
11/24/2009 9:40:26 AM ~!~COM Plugin Info~!~Initializing RFRemote ...
11/24/2009 9:40:26 AM ~!~Warning~!~'status' property on device Computer Remote Control was accessed - this property has been deprecated and should not be used.
11/24/2009 9:40:26 AM ~!~RFRemote startup~!~Done Initializing RFRemote
Is there anyway to eliminate it or is it benign such that I should just ignor it?
HEC
November 24th, 2009, 12:43 PM
Location: Troutdale, Oregon (go to Portland, head east)
Do a board search for:
and all your questions shall be answered.
It is not specific to this plugin.
~Bill
November 30th, 2009, 11:21 AM
DooSeer
I have not touched this plug-in in over 5 years. I didn't think anyone was using it. I just looked and cannot find the source, so I am unable to correct the issue. With newer PCs, I doubt that having the RFRemote.txt file in memory saves that much processing time.
November 30th, 2009, 08:10 PM
Thanks for the response. I have no problem with this. Since having first posted this I've learned a lot and know that this is really a nit.
HEC
November 30th, 2009, 09:17 PM
DooSeer
I quit using the RFRemote.txt file feature myself even though I have used my MR26A as my whole house motion RF transmitter for years. I might try utilizing that feature again.
November 30th, 2009, 09:20 PM
DooSeer
I am using the ACRF Plug-in now, so I wonder if it even supports the RFRemote.txt file. I'll have to check into that.
| Thread Tools |
| Display Modes |
Linear Mode
