Go Back   HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific
HomeSeer HS2™ Specific General discussion about HomeSeer HS2.
View Poll Results: HS v2.4 feedback
Updated to v2.4... and staying 58 75.32%
Updated to v2.4... and decided to go back to 2.3... 2 2.60%
Updated to v2.4... and decided to go back to 2.2... 0 0%
Will update to v2.4 when you have more time 17 22.08%
Voters: 77. You may not vote on this poll
Old November 24th, 2009, 07:40 PM
megatron2 megatron2 is offline
Default Poll - HS v2.4... or 2.3... or 2.2...
I am thinking about updating to HS2.4, but just wanted to get a little feedback from the users. It is sometimes hard to tell by just following the "release" thread how things are going...
Old November 24th, 2009, 08:27 PM
nightwalker nightwalker is online now
Default
I'm still at 2.3.0.19, everytime I update too soon WAF drops like a rock.
Marty
XPpro SP3 /w HS 2.4.0.6
Old November 24th, 2009, 08:44 PM
Default
I know what you mean about decrease in WAF... mostly due to my time spent tweaking things more than her dependance on the system.
I am pretty content at 2.3.0.86, but I am in the process of moving to a newly built HS Server and was debating doing a Full Install with v2.4.0.1. or just trying to get 2.3.0.86 running smoothly then update to v2.4.0.1 later.
Based on the poll results so far... I am starting to lean toward going straight into v2.4.0.1
Old November 24th, 2009, 08:48 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Default
Hey, jump in... the water's fine! The beta versions leading up to 2.4 were really beat on pretty good. It's very solid.
website | products | support | wiki | youtube
Old November 25th, 2009, 07:24 AM
ArbWare's Avatar
ArbWare ArbWare is offline
Default
Upgrade to 2.4 was pretty painless for me...
I did a couple of the betas (2.3.0.130 or so..) and didnt' have any large problems....
If you are on z-wave... you need to rescan (at least i did) all nodes... but everything went smooth...
I don't have anything "exotic" ... and the only error i have is a note on bootup from ACRF2 that one of the calls it uses has been depreciated... (Will be removed from H.S. in future?)
Running 3 days now... no issues.
Andrew B.
Old November 25th, 2009, 07:58 AM
kaldoon's Avatar
kaldoon kaldoon is offline
Default
2.4.0.1 is solid - Motion Sensors are running much more reliably
Old November 25th, 2009, 08:23 AM
dschoppe dschoppe is offline
Default
I voted that I'd update to 2.4 when I have more time, but actually I'm just waiting for the 64-bit Way2Call drivers so that I can begin with a fresh install of 2.4 on a new Win7 x64 PC.
Don
Old November 25th, 2009, 09:22 AM
sonypoolplr sonypoolplr is offline
Default
I went to 2.4 and I haven't seen any problems.
Old November 25th, 2009, 12:42 PM
krmiller53's Avatar
krmiller53 krmiller53 is offline
Thumbs up Operational with 2.4
My update process was a bit of a PIA due to some battery devices I have and my limited time to play, all functions are operational and happy now. Been up and running with 2.4 for several days.
ken
Old November 25th, 2009, 01:44 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Default
same here - 2.4 seems to be the most stable in quite a while.
Dell P4 1.4Ghz / 2G RAM
HSPRO 2.4.0.1/ Z-Troller / Z-Wave devices / 2 WDTC-20 thermostats
Z-Troller v1.12 / TI-103 / WGL800 / RFXCom / Oregon Scientific Sensors / Motion Sensors / X10 devices / DS10a
Check out Homeseer's YouTube Channel!
Old November 25th, 2009, 01:50 PM
twa8000 twa8000 is offline
Default
2.4 is the way to go..
Old November 25th, 2009, 01:55 PM
tmcgowan's Avatar
tmcgowan tmcgowan is offline
Default
I'm very happy with 2.4!!!!
-Todd
____________________________________________________________ ________________
HSPro: 2.4.0.6 Plugins:| DooMenuBar | DooMotion | DooNetwork | Smarthome PowerLinc USB | Power Monitor | iAutomate RFID | SmartLinc TempLinc | CX777ES | mcsTemperature | Global Cache GC100 | VWS | HSTouch | RFXCom | ROC Randomizer | ISY/99i v.1.0.1.0| iTunes | Maestro |Z-Wave
Old November 25th, 2009, 03:13 PM
neiltimms's Avatar
neiltimms neiltimms is offline
Default
2.4.1 does not work with my HSM100's I tried all kinds of configuration including setting sensitivity to 0 and yet they all still see phantom motion. Even when the house is completely empty. Switched back to 2.3 and all is well again.
Running HS PRO V2.4.0.6
X10 CM11A/CM12U, BLEditor, BLRandom, BLGarbage, AC-RF2 Processor, DooMotion, Global Cache GC100, HomeSeer Log Monitor, Skype Connector, UltraMon, VWSCSV, ZWave Thermostats, HSTouch Server, iTunes, Script Connector.
2 x Z-Troller Interfaces
Old November 25th, 2009, 08:03 PM
langenet's Avatar
langenet langenet is offline
Default
When you say stable, what are you referring to? I'm running 2.3.0.19 and think it is rock solid as well. I do notice a bit of memory creep (not serious) after 30 days or so - not such a big deal since I ghost every 30 days anyway.
I have yet to jump on the Z-wave bandwagon - though from what I have read, this is likely the most compelling reason to upgrade.
Robert
Old November 25th, 2009, 08:10 PM
rmasonjr's Avatar
Default
Robert
Sorry - was referring to the betas that preceded this release. I should have clarified that.
Old November 25th, 2009, 08:13 PM
johnnybwis johnnybwis is online now
Default
I have no interest in z-wave. Should I upgrade?
John
Old November 25th, 2009, 08:24 PM
langenet's Avatar
Default
Ah... yes, well then - if it aint broken...
For myself, my X-10 works great, though I am interested in the Schlage Z-wave lock - which is why I'll upgrade at some point.
I'm almost getting to a stage that I don't want to rock the boat with my system. That is, there are no weird errors, system is stable, reliable and I'm beginning to depend on it. So I get nervous with making any major changes to it as I don't want to spend a weekend fixing it. (too much like work - if you know what I mean!) ... and yes, I am well backed up. On second thought, since winter is coming and we may get snowed in at some point, that could be a good way to spend the time.
Robert
Old November 26th, 2009, 11:41 AM
Default
I don't use Zwave either, however I will upgrade sooner rather than later. I notice that things get weird if you get too far behind in versions and an update comes out with features you really do want.
Marty
Old November 26th, 2009, 12:16 PM
Default
Thank you for all the feedback...
My plan is to make yet another full backup of my HS directory
Update to v2.3.0.137 beta (based on the feedback that jumping from v2.3.0.86 to v2.4.0.0 had some issues).
Launch HS running v2.3.0.137 beta.
Close HS and then update to v2.4.0.2
Do all the full rescan business, optimize three times, and hope all goes well. I only have intermatic wall switches, lamp modules, and relay modules being controlled by a Z-troller... so hopefully I will not run into the "root device" issue that some had to make adjustments for.
If all goes well on my current HS Server... then I will proceed to the process of a new full install at v2.4.0.2 on my new HS Server.
Old November 27th, 2009, 09:35 AM
macromark's Avatar
Default
Neil - When/if you try again, be sure to wake the sensor up and do a rescan on each. Then, they should work fine with v2.4.
Mark
