Go Back   HomeSeer Message Board > Automation Protocol Support > Z-Wave General Discussion
Z-Wave General Discussion Discussions relating to the Z-Wave automation support in HomeSeer.
Closed Thread
Old November 25th, 2009, 01:54 AM
Juliusachim Juliusachim is offline
Default Automatic polling z-wave?
Hello,
homeseer works fine with my düwi-switches. But if I e.g. put the lights manual off, homework says, that the lamp is on. If I press the polling-button in Homeseer, the status is changing.
Can Homeseer make this automatic?
(Sorry for my bad english).
With greetings from germany
Old November 25th, 2009, 08:27 AM
sonypoolplr sonypoolplr is offline
Default
I believe that you can go to the device properties of the switch that you want to know the status of and set HS to poll the device every x seconds. It won't give you instant status updates, but if you set it around 10 to 30 seconds you will then let HS know the status of the device.
Hope that helps.
Old November 25th, 2009, 03:14 PM
Default Thanks - but how can I make this?
Do you know, how i can "say" my switch to send the status in homeseer? In the "Action List" is no entry with polling or something.
Best regards
Uwe
Old November 25th, 2009, 03:26 PM
Wadenut's Avatar
Wadenut Wadenut is online now
Super Seer
Default
If the switch supports association, you can associate it to the controller node (Homeseer) and it will send status changes. This is about 99 & 44/100% reliable with my Intermatic switches. Just click on the device name on the status page. If the switch supports it, there'll be an option there. It's fairly self explanatory.
Automate everything, modify the rest... but remember... For every action, there is an equal and unexpected reaction.
Old November 25th, 2009, 04:09 PM
Default
Hello,
I did the association between the dimmer switch and homeseer. But If I change the lightpower with the wall-switch, homeseer does not know it - until I press the button polling.
Is there no way to say Homeseer "autopolling"? Perhaps with a script?
Best regards
Old November 25th, 2009, 04:28 PM
wpiman's Avatar
wpiman wpiman is offline
Default
Originally Posted by Juliusachim View Post
Hello,
Best regards
It is built in.. see second post...
HS 2.4.0.56 Beta; Z-Seer 1.2 with ZStick (32 devices)
Operating System: Microsoft Windows XP Professional - Work Station;
OS Version: 5.1.2600 Service Pack: 3.0;
Plug-Ins Enabled: ZWave Thermostats, HSTouch Server, TED, HSTouch Server Unlimited,
Media Player, HSTouch iPhone, CheaperRFID Plugin, AC RF Processor,
iTunes, WeatherPLUG
HSM100, HRDS1, Schlage Locks..............
Closed Thread
