| HomeSeer HS2™ Specific General discussion about HomeSeer HS2. |
November 28th, 2009, 06:33 PM
Enable / disable plugin form events
Hi All,
I'm looking for a way to disable some plugins from events and enable them again from event.
Main reason for this is the slow startup of HS
Homeseer startup will take about 5 minutes on my system.
I have about 18.000 tracks and this need some time.
Idea is to disable Itunes by shutdown en enable it after HS is running for few minutes.
November 28th, 2009, 07:33 PM
I do not believe you can disable plugins from events.
-Rupp
November 29th, 2009, 07:16 AM
@Rupp,
Can this be done with a special plugin or scripting?
Or maybe Homeseer can delay the Itunes startup
November 29th, 2009, 02:32 PM
I thought Jim DooLittle posted a plugin that allowed you to select the order that plugins were loaded but I can't find that. Maybe someone else will remember.
-Rupp
November 29th, 2009, 04:12 PM
thanks..
Can't find anything on the the site..
November 29th, 2009, 04:45 PM
As far as I know, this is not possible.
The plugin has to implement a delayed startup feature itself.
All my plugins have a delay startup feature (because I use this for debugging purposes), but it's really up to the plugin author to implement this.
November 29th, 2009, 04:47 PM
You can at lease add move the iTunes plugin to the last entry in the list of IO plug-ins in the INI file to make it startup last.
-Rupp
November 29th, 2009, 06:16 PM
Thanks for the Tips.
Hoop Rich can change this in itunes.
itunes is already the latest in my list.
Webserver will not load before itunes is ready.
29-11-2009 23:13:32 Plug-In Finished initializing plug-in iTunes 29-11-2009 23:13:32 iTunes Finished loading Playlists 29-11-2009 23:13:32 iTunes Found 17 total playlists 29-11-2009 23:13:32 iTunes Warning, could not add voice command for album Whose Side Are You On?:Item has already been added. Key in dictionary: 'Whose Side Are You On' Key being added: 'Whose Side Are You On' 29-11-2009 23:13:32 iTunes Finished loading tracks library 29-11-2009 23:13:32 iTunes Loading 0 tracks from a Radio Tuner... 29-11-2009 23:13:32 iTunes Found 2 total sources 29-11-2009 23:13:28 iTunes Loaded 18500 tracks... 29-11-2009 23:13:23 iTunes Loaded 18000 tracks... 29-11-2009 23:13:18 iTunes Loaded 17500 tracks... 29-11-2009 23:13:13 iTunes Loaded 17000 tracks... 29-11-2009 23:13:07 iTunes Loaded 16500 tracks... 29-11-2009 23:13:01 iTunes Loaded 16000 tracks... 29-11-2009 23:12:56 iTunes Loaded 15500 tracks... 29-11-2009 23:12:51 iTunes Loaded 15000 tracks... 29-11-2009 23:12:46 iTunes Loaded 14500 tracks... 29-11-2009 23:12:41 iTunes Loaded 14000 tracks... 29-11-2009 23:12:36 iTunes Loaded 13500 tracks... 29-11-2009 23:12:32 iTunes Loaded 13000 tracks... 29-11-2009 23:12:27 iTunes Loaded 12500 tracks... 29-11-2009 23:12:23 iTunes Loaded 12000 tracks... 29-11-2009 23:12:19 iTunes Loaded 11500 tracks... 29-11-2009 23:12:16 iTunes Loaded 11000 tracks... 29-11-2009 23:12:12 iTunes Loaded 10500 tracks... 29-11-2009 23:12:08 iTunes Loaded 10000 tracks... 29-11-2009 23:12:04 iTunes Loaded 9500 tracks... 29-11-2009 23:12:01 iTunes Loaded 9000 tracks... 29-11-2009 23:11:57 iTunes Loaded 8500 tracks... 29-11-2009 23:11:53 iTunes Loaded 8000 tracks... 29-11-2009 23:11:50 iTunes Loaded 7500 tracks... 29-11-2009 23:11:47 iTunes Loaded 7000 tracks... 29-11-2009 23:11:44 iTunes Loaded 6500 tracks... 29-11-2009 23:11:42 iTunes Loaded 6000 tracks... 29-11-2009 23:11:39 iTunes Loaded 5500 tracks... 29-11-2009 23:11:37 iTunes Loaded 5000 tracks... 29-11-2009 23:11:35 iTunes Loaded 4500 tracks... 29-11-2009 23:11:32 iTunes Loaded 4000 tracks... 29-11-2009 23:11:30 iTunes Loaded 3500 tracks... 29-11-2009 23:11:28 iTunes Loaded 3000 tracks... 29-11-2009 23:11:26 iTunes Loaded 2500 tracks... 29-11-2009 23:11:24 iTunes Loaded 2000 tracks... 29-11-2009 23:11:23 iTunes Loaded 1500 tracks... 29-11-2009 23:11:21 iTunes Loaded 1000 tracks... 29-11-2009 23:11:20 iTunes Loaded 500 tracks... 29-11-2009 23:11:18 iTunes Found 18805 total tracks, loading library... 29-11-2009 23:11:18 iTunes Loading library in the background, this could take a few minutes... 29-11-2009 23:11:18 Plug-In Initializing Plug-in: iTunes
| Thread Tools |
| Display Modes |
Linear Mode
