Go Back   HomeSeer Message Board > HomeSeer > General Discussion Area
General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old November 29th, 2009, 01:25 AM
sleighbor sleighbor is offline
Question Doorbell
Hey guys,
I need to get a new doorbell at home. I do not have one currently. Is there a doorbell for z-wave or x10?
Thank you.
Kevin
Old November 29th, 2009, 01:49 AM
Czechmarty's Avatar
Czechmarty Czechmarty is offline
Default
Many possibilities. It will depend on your equipment.
I have my connected to Ocelot, many use DS10A, etc.
Marty
A Person is Smart. People are Dumb, Panicky Dangerous Animals.
1,500 years ago, everybody knew that the Earth was the center of the universe.
500 years ago, everybody knew that the Earth was flat.
15 minutes ago, you knew that humans were alone on this planet.
Imagine what you’ll know tomorrow.
TLJ in MIB
Old November 29th, 2009, 08:01 AM
nojstevens nojstevens is offline
Default
I used DS10A with RFXCOM and it was very simple - the plunger on the regular doorbell triggers an X10 wireless signal to the RFXCOM receiver/plugin and I can then prompt actions/scripts from that
Jon
Old November 29th, 2009, 08:04 AM
Pete's Avatar
Pete Pete is offline
Super Seer
Default
I have my doorbell connected to my alarm panel. Ideally though I would have like to keep the button illuminated and I guess the best way to do that would be some sort of a circuit which would provide the illumination and a NO/NC switch with just two wires. Or maybe 4 wires (two for an LED and two for the switch). Next year we are redoing the front entrance of the house and installing a new door with side panels replacing the current one. While the door is off was going to re-wire the area and most likely will include four wires for the door bell. (adding a camera there too).
Base HW & SW: P4 2.97 GHz / 1Gig / MS Server 2003 - creating duplicate server
HS Version Pro 2.4.0.11 pending migration to new computer-Mini-ITX based
HAI OmniPro II X 2 @ FW V3.2D (new 3.3 FW is out?)
Powerline: X-10 & Insteon & UPB (testing) Pending Z-Wave - UPB testing begins with 3 switches for now.
Sound - Current 10 pairs of speakers for HS and music- 6 local subzones -AB8SS- readdressing methodologies / HS control - bought a Russound/KPLs to play with for now.
Old November 29th, 2009, 01:40 PM
Rupp's Avatar
Rupp Rupp is offline
Default
I would recommend doing a search on this as it has been covered many times. I put the magnet of the DS10A door and window sensor next to my plunger and it triggers and event in HomeSeer. This way I do not have to modify my door bell at all. I posted pictures a while back.
-Rupp
Old November 30th, 2009, 11:29 AM
Default
Thanks for the replies guys. I was hoping there was just a wireless doorbell I could buy that was z-wave or x10 enabled. I guess not.
Will this DS10A solution work with an inexpensive wireless doorbell I can buy at Home Depot?
Thank you everyone.
Kevin
Old November 30th, 2009, 11:44 AM
Rupp's Avatar
Default
See this post for pictures of my setup. This is a cheap door bell from one of the chain stores.
http://board.homeseer.com/showthread...light=doorbell
-Rupp
Old November 30th, 2009, 12:18 PM
Default
I think I got it now! Thanks for the help with this.
Kevin
Old November 30th, 2009, 01:19 PM
Pete's Avatar
Super Seer
Default
Rupp's method is plug n play and really non invasive.
I removed my doorbell (and shouldn't have) wiring the doorbell directly to the alarm panel (it still works if there is a power failure via alarm panel battery). The wires are still there though. Currently it dings the alarm panel consoles, HS TTS and chimes. In addition it triggers a number of events - video recording etc.
