Originally posted by Dafunktyfunk
View Post
HD11A X10 Woes! Can see in but
Originally posted by Rupp View PostDid you use another software to load data to the CM11A before? If so you may want to clear the memory using the old software and see if this helps. I've never experineced a lamp module not working in the same outlet as the X10 interface so there may be something up with the interface.
You know what!!!??!?!? YOU'RE right. I used this module like 8 years ago in an old IBM director software. It has been in a box unused for 7 of those years. I took it out of the box yesterday to start working with it. The software is long gone and will only run on win98 so I am not able to load it as I am running Win 7 x64.
I wonder how I can clear it now... Suggestions?
This computer has not used any other software to control x10 and the HD11A has not been used with any other software.Transitioning to HS3Pro .298 - WinXPEmbedded
Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
Originally posted by Dafunktyfunk View PostYou know what!!!??!?!? YOU'RE right. I used this module like 8 years ago in an old IBM director software. It has been in a box unused for 7 of those years. I took it out of the box yesterday to start working with it. The software is long gone and will only run on win98 so I am not able to load it as I am running Win 7 x64.
http://store.homeseer.com/store/X10-C45.aspx
Originally posted by Rupp View PostIf you are going to stick with X10 I would recommend a TI-103 as this is the best X10 controller left.
but my usb 1132u will have to die first!!!!!
i agree that the cm11a should be replaced with something better...HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
got my xpcr in today from ebay... and installed in 3 minutes.... and BACK IN BUSINESS!!!! all my xmas lights are working again... so was my problem... all my x10 woes are gone AGAIN!!!!!!!!!!HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by Dafunktyfunk View PostThat is good news!
I hope mine comes in soon!
yeah you will see a difference.. but you still have to realize if you get it working great.. and it stops.. what was the last thing you plugged in..
i have a whole box of z-wave stuff to put in.. but i refuse to get rid of my x10!!!!!!!!!! HAHHW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
