I'm trying to deploy an project to an Android Tablet. This project uses the function (HSTouch ->Tools-> Options-> Project defaults-> 'Return to main screen after ... minutes after inactivity. It works fine when deploying to an iPad but the Android Client fails to go to the main screen, instead it uses the first screen created in HSTouch. Does anyone know how to solve this?
I'm using the latest HSTouch plugin, HS3, the latest Designer and the latest Android Client
With kind regards,
Sander
Edit: I found out I had the status 'IsMain' set at two different screens. Setting just one screen obviously solves the problem.
With kind regards,
Sander
