When I put the dimension statements in the ini there was no effect. When I used DeviceAlt, the icon disappeared entirely.
Jon00 Homeseer 2 web page (Quick view) builder Version 2
I think that's what I'm doing. I've attached two screen shots. The first has all items with the standard 'Device##' and the second uses the following:
Column3Section1-19Left=Shed
Column3Section1-19Right=DeviceO9
Column3Section1-20Left=LR Chair
Column3Section1-20Right=DeviceAltP4
Column3Section1-21Left=Den
Column3Section1-21Right=Device'1
Column3Section1-22Left=Office
Column3Section1-22Right=Device'3
Column3Section1-23Left=Christmas Tree
Column3Section1-23Right=DeviceP5Mike____________________________________________________________ __________________
That was it. What fooled me was that the version I was using had the icon size modification included.
So the image size issue is resolved, but now it can't find some of my custom icon files. I'm betting I need to move them to the HS icon folder.Mike____________________________________________________________ __________________
can't view .ash remotely?
It works fine on my local machine. When I try to view remotely /Buildpage.ash?val=qv I get:
File not found: C:\Program Files\HomeSeer HS2\html\buildpage.asp
When I try to use the redirect.asp I get:
What am I missing? I saw a few examples of people serving their .ash pages Why can't I?
Originally posted by jon00 View PostI'm not sure.
Let's just check a few things again.
Log on remotely and display your Homeseer status page. Once this is showing correctly, replace the /stat in the URL to /buildpage.ash?val=qv
What happens?
Originally posted by jon00 View PostAlso does redirect.asp work locally OK?
Script Error:
File not found: E:\Program Files\HomeSeer HS2\html\buildpage.asp
What exactly is a .ash file? I think I read somewhere it's encrypted? Thanks for any help with this.
Originally posted by jon00 View PostIf you logged on remotely and looks good, it must be working?
You are correct that ash files are encrypted versions of asp files.
Open up redirect.asp in a text editor and change the URL within to \buildpage.ash?val=qv
Save it and the redirect.asp should work.
Script Error:
File not found: C:\Program Files\HomeSeer HS2\html\unauthorized.asp
It does redirect locally now though.
Update: I got it. sort of I changed my web server setting to Allow "../" File Access:Yes, and it works for admin login, but not guest. Does this sound right? I would like it available to guests as well. Thanks for following along with this.Last edited by Isk82; October 9, 2010, 11:38 AM.
I consider it a bug in Homeseer but you cannot call .ash pages with the '?val=qv' extension bit as a home page (i.e. defining it as your Custom Web Page 1 URL/Link under web page setup). The redirect.asp was to get around this limitation.
You don't actually need the redirect.asp anymore as I added a feature which allows you to just call buildpage.ash on it's own and it will by default look for the ini file called homepage.ini.
