Unable to connect with HSTouch but can with Android with errors?
    #16
    I checked with Verizon - they're not blocking any ports.
      #17
      Wow. Really. Nobody has it working?
        #18
        Hello,
        I had the same problem with the client android, it has been solved when I have forwarded port 10200 in TCP and UDP !
        Cordially
        Doryphore
          #19
          Meofleur, I realize I'm posting this 4 years later, but I have the same problem at the moment. Access via web using a dynamic DNS address works fine, but local access doesn't work. Did you ever find a solution?
            #20
            I am wondering if this is related to a recent release. I am unable to connect with my android clients right now. Even if they do get connected, they time out and do not update.
            iOS clients are OK.
            Windows client also appears to be hosed.
