Originally posted by ameridan
View Post
Jon00 Remote Computer Control & Network Monitor (HS2, HS3 & HS4)
After trying to update the HSTouch plugin to the latest one last night and failing (didn't know you needed .80 and didn't check the logs until later on :/ ) I deleted and uninstalled the old hstouch plugin thinking it might be a locked file or something.
Anyway, now I'm on beta .81 and the new hstouch plugin and I get the error below every few seconds.
But all devices seem to be working ok.
Apr-18 07:11:17 Jon00_RCCNM Error in updateVD subroutine Block 5: (Conversion from string "4/18/2014 12:12:50 AM" to type 'Date' is not valid.)
Cheers
J
Originally posted by travisdh View PostHi Jon00,
I noticed this in my log from version .81 of HS3.
18/04/2014 12:04:14 PM ~!~Error~!~Saving INI file: Collection was modified; enumeration operation may not execute. File:C:\HomeSeer HS3\Config\Jon00RCCNMData.ini
This repeats lots.
Originally posted by Skinnez View PostAfter trying to update the HSTouch plugin to the latest one last night and failing (didn't know you needed .80 and didn't check the logs until later on :/ ) I deleted and uninstalled the old hstouch plugin thinking it might be a locked file or something.
Cheers
J
Try this: http://board.homeseer.com/showpost.p...&postcount=104
Hi Jon,
More just an FYI than anything else, but it looks like (at least in my system) the ini functions are not working correctly.
I had tried renaming the file as per your suggestion, or deleting it and both gave the same errors eventually:
Hi Jon,
I updated to the latest version, but have kept my previous config files (so really just updated the scripts and so on). I noted in my log that I am getting errors as per below, even though I can confirm the file does exist:
Apr-30 12:32:58 PM Jon00_RCCNM Error: Cannot find Jon00RCCNM_MonitorHS3.vben in the scripts directory
Is there a version check feature or something similar that I should be updating given I did not copy across the (new) config files to get this working?
I should note it does seem like sometimes the intrusion stuff works, other times it does not so I don't think this problem is all or nothing. I did forget about the scripts too lol, and got some very loud TTS about unknown devices (which have been added) lol.
This has largely been working quite well on my system, the other thing I did notice is the following error, it appears to happen when I try to do something by script, but if I try it through an immediate script command it (seems) to work fine:
Apr-30 10:52:34 AM Error A call was made to save a global variable (Jon00RCCNMPort8840) but that global variable has not been defined. Apr-30 10:52:34 AM Warning A call was made to retrieve a global variable (Jon00RCCNMPort8840) but that global variable has not been defined
