Once a devicestring is set, it will stay. Please delete the device.
Jon00 Homeseer 2 - Homeseer 3 - Homeseer 4 Connector
Still available?
Is this still available for download? I searched around and couldn't find it. I would really like to give this tool a try rather than rebuild my events; got my devices rebuilt with just a few that need to be deleted and re-created...z-wave devices.
I don't use them all but I have over 400 events in my old HS2Pro setup, and don't want to have to rebuild all the ones I still use.
Hello Jon,
The HS2 to HS3 connector was very good working until now:
I have upgraded HS3 from .130 to .143. .
Since then I get the following log error message:
Dez-09 20:28:55 Error A call was made to save a global variable (Jon00GW) but there are none defined in the system.
Where is the issue ?
Regards,
Fischi
Hi Jon,
I seem to have the same problem as Daarn a couple of pages back. I can Mirror devices from HS2 to HS3 fine, but i can't execute an event, hslog or direct control a device in HS2 from HS3.
I tried adding "Event XXXX" and "HSLog Hello World" in global variables directly like you suggested but nothing triggers in HS2.
HS2 and HS3 are on the same machine. HS2 webserver port is 82 and HS3 is 83 if that makes any difference as i noticed direct control is via webserver.
Rob
HS3 to HS3 connection
Hi Jon,
I need to connect two HS3 installs...I got everything installed but it doesn't look like it's creating devices in the respective HS3's. It gets a little confusing because everything is referencing HS2 on one end and HS3 on the other and it's not clear how to do HS3 to HS3. I just created a dummy device L1 on client 2 and it did not replicate. I'm not getting any errors in log. and the program starts fine. Any ideas?
HS3 Server 1 - 172.25.25.30
HS3 Server 2 - 172.21.65.30
Client 1 HS3Settings file
hs3hostadd=172.21.65.30
hs2clientadd=172.25.25.30
porta=9010
portb=9020
clientno=1
Client 2 HS3Setting File
hs3hostadd=172.25.25.30
hs2clientadd=172.21.65.30
porta=9020
portb=9010
clientno=2
Client 2 HS3Devices
L1 x41 0
Philip
pabbott@cpak.com
HS3 ---> HS3 Problems
Jon,
It still doesn't seem to work. Here's the files after changes. There are no errors in log.
This is the device I created on 172.21.65.30
Off Unknown Unknown Test Device From office L1 Today Off ON Test1
(a virtual device with 3 values (Off, On, Test1)
HS3Settings file - 172.25.25.30
porta=9010
portb=9020
HS3Setttings file - 172.21.65.30
porta=9020
portb=9010
HS3Devices file - 172.21.65.30
L1 1 2
Any ideas? Thanks very much.
Philip
pabbott@cpak.com
