Using the marquee or the postit script, how would you get the device string/value/status to display as the message?
Thanx
Tim
Thanx
Tim
void Main( object param ) { MarqueeForm marqueeForm = new MarqueeForm( hs.DeviceString("A1") ); Application.Run( marqueeForm ); }
void Main( object param ) { PostItForm postItForm = new PostItForm( hs.DeviceString("A1") ); Application.Run( postItForm ); }
void Main( object param ) { PostItForm postItForm = new PostItForm( hs.DeviceString( param.ToString() ) ); Application.Run( postItForm ); }
