SIP Connector Hint Subscription Fo rPBX Night Mode
Hi
I have performed some more testing and it looks like the SIP connector never contacts Asterisk after the first subscription to the hint/BLF on *280. After 3600 seconds Asterisk then terminates the connection as the timeout valuse for the subscription is 3600 seconds.
Data showing Asterisk to HS timout cancelling subscription after 3600 seconds:
*CLI>sip set debug ip 192.168.0.81
From: <?xml:namespace prefix = sip /><sip:*280@192.168.0.175>;tag=as38a7c11c
To: Asterisk_PBX1_100<sip:100@192.168.0.175>;tag=90ada3954fbd424 a6c02436306c70326
Contact: <sip:*280@192.168.0.175:5060>
Call-ID: ssc-183119bedaa032be06320d598179c039@ab660ce8dc093516bbd5b72029e c9fdd
CSeq: 103 NOTIFY
User-Agent: FPBX-2.11.0beta2(11.1.2)
Subscription-State: terminated;reason=timeout
Event: dialog
Content-Type: application/dialog-info+xml
Content-Length: 206
<?xml version="1.0"?>
<?XML:NAMESPACE PREFIX = [default] urn:ietf</dialog-info>arams:xml:ns:dialog-info" version="1" state="full" entity="sip:*280@192.168.0.175">
<dialog id=*280>
<state>terminated</state>
</dialog>
<--- SIP read from UDP:192.168.0.81:5060 --->
SIP/2.0 200 OK
Call-Id: ssc-183119bedaa032be06320d598179c039@ab660ce8dc093516bbd5b72029e c9fdd
Cseq: 103 NOTIFY
Via: SIP/2.0/UDP 192.168.0.175:5060;branch=z9hG4bK5c4a636b;rport=5060
Date: Wed, 06 Feb 2013 13:06:36 GMT
User-Agent: HomeSeer
Accept-Language:
Contact: <sip:192.168.0.81:5060>
Content-Length: 0
If I subscribe to vmx via the IM connector I can see regular requests from HS to Asterisk to keep the hint subscription alive but I don't see regular subscription keep alives from HS to Asterisk for the night mode BLF subscription on *280. Is there any way around this? My HS PC needs to know is the PBX is in day or night mode and act accordingly.
</sip:192.168.0.81:5060></sip:100@192.168.0.175></sip:*280@192.168.0.175></sip:*280@192.168.0.175:5060></sip:100@192.168.0.175></sip:*280@192.168.0.175>
Don't know if this was given up on but I have the same problem the subscriptions connection from the SIP connector just stop happening so what I did is create an event to restart the sip connector every 65 min and that has it working. Wish it worked correctly but at least this is a work around.
script is attached just remove the txt at the end it is a vb script.HS2 Environment
Zotac 1.83 GHz Quadcore
HomeSeer Way2Call
Netiom-Xap board
opnode 1-wire 1.2.7
Plug-In's
WeatherXML 1.0.0.32
Pwr Link USB 1.0.0.13
mcsTemp V6.2.0.14
mcsXap V3.0.0.0/3.0.0.20
IM Connector 4.87.2.5
Sip Connector 2.56.2.4
RFXCOM 15.0.0.22
Odroid X2
Asterisk 11.5.1
FreePBX 2.11.0.42
WebMin 1.720
Xap Switchboard by Mi4
There is no place Like 127.0.0.1
