Shows you have a good grasp on how it works and publishing your results (Hint Hint)
Jon00 Homeseer 2 web page (Quick view) builder Version 2
Nag, Nag, OK, I get the hint, I've kept them simple but useful and i'll post in a bit. You'll make someone a great wife one of these days.
Sorry, couldn't resist a little fun.Marty
Originally posted by jon00 View PostThe width of the left sub-column is defined using:
ColumnXSectionXWidthLeft=xxx in pixels
The width of the next is defined using:
ColumnXSectionXWidthRight=xxx in pixels
If you look at the sample qv.ini file it shows all the possible ini file settings. Also read the docs - or as I aways say to TrOjAn RTFM...everything is explained
and yes I was reading the doc... well laid out I must add
I just removed the weather pic and totally screwed it up!!!! so yeah I gotta look at those sections yall are saying to get it all back in order.....HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
well i figured out my problem.. it was not with each section.. but apparently I left the defaults at the top of the section......
ColumnNumber=3
Column1Width=25
Column2Width=50
Column3Width=25
so I changed it to
ColumnNumber=2
Column1Width=40
Column2Width=50
Column3Width=
and now it looks better...HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by jon00 View PostOnce you get used to the methods, its really quite easy to build a page. You will never get the totally flexibility of hard coding a page but I think this second version comes a long way to fulfil most peoples requirements.
is there a way to do this?
can I set a function at the bottom of the page and call it as the device?HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by nightwalker View PostThis is the one I whipped up to access from the PPC, nothing fancy just basic status. There's only so much you can do with that little screen anyway. Only a piece of it shows on the graphic but I've attached my ini file just in case it might be useful for someone.
Originally posted by jon00 View PostIn V2.03, yes.
Use DLT(Housecode) in the text - similar to DLC(Housecode)
thanks jon00
Originally posted by jon00 View PostThanks for posting Marty. That is exactly what I'm asking people to upload.HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
My confusion is, after installing the new version it still works as it did before, i was expecting to have to go into the buildpage.vb and put that section back in before it would work.
It's working with out it, even though I'm calling a BPVar50 and there isn't one, it's just working with no error message either.Marty
Originally posted by nightwalker View PostA quick question, I'm just a little confused. I just downloaded and installed the new version, 2.0.3 i think, whatever one is on your web site now. Anyway A few days ago I started using a BPVar50 that you gave me to get a mini logo bar on my ppc screen, you see it above in the picture.
It may be that the default just shows the logo without the links.
Originally posted by jon00 View PostMarty, I'm not sure what is going on (open up buildpage.vb to make sure the code is there), however I did add your feature request for just the clock/sunrise etc but without the links. There is a new setting so that you can choose the entire logo bar with links, without links and nothing at all.
Maybe it's just stuck in my cache or something, very strange. I did see the settings for logobar to show or not. I even turned it on and off just to see what it did, It put the entire logobar on and took it off but never effected the BPVar50 section, you know the one that's not in the new buildpage.vb.
What i have for the BPVar50 is only a represent ion of the logobar, not the real one. It never did include the HS graphic like the real one does. Right now I'm at a loss as to where it's coming from. I do love a good mystery.Marty
