I have a 3-story house, 4 if you count the attic. I have an available RG6 cable running from my basement (where my HS server is) all the way to my attic. I have installed the WGL800 in the basement and placed the antenna down there, but I'm finding that my signal to the motion detectors on the upper level is sporadic. I was wondering if I could "split" the signal and install multiple antennas in series, like this:
WGL800
|------(antenna)
|------(antenna)
etc.
Or should I do this:
WGL800
/\ Splitter
/ \---Antenna 1
/---Antenna 2
Or will neither of these work? Or will the cable itself act as a better and better antenna if I simply terminate in the Attic some 50 feet away from the 800?
WGL800
|------(antenna)
|------(antenna)
etc.
WGL800
/\ Splitter
/ \---Antenna 1
/---Antenna 2
