I have 9 WDTC20 thermostats and I'm using scripts to set setpoints and modes on the fly using tstat scripts that use thermostat number. I want to be able to write the results to a database which uses the tstat device name as a field. Is there a script command to be able to pull the homeseer device name by thermostat number?
