I'll continue the remote thermostat control if there is any interest...
In the meantime, here is a new script to control lights. It shows a semi-transparent slider with light status. If you click the small light icon, the light is switched on/off. If you move the slider, the corresponding DIM or BRIGHT command is sent. A tooltip showing location + name is shown if you leave the cursor over the slider.
You can run several simultaneous remote light scripts. You select the device by passing device house code + device code as the script parameter.
You have to make sure the following picture files are present on the remote computer (you may copy the files from your main HS server)
[EDIT] Script removed as a new fixed version is available in the plugin V0.6.2.2 package.
