Radio Shack IP Cams for $25
    Try as I may I cannot get the software to install on my w7 machine. I'm trying in compatibility mode, sp2, sp3, it seems to always hang on 99% extracted. any ideas?
    Ian
    Originally posted by Pete View Post
    Updated FW on IPCams that I purchased. Easy. Here are the instructions. If you have never done anything like this or do not feel comfortable doing the firmware upgrade please don't attempt it; you can brick your camera.
    Download the software used to flash the firmware at:
    http://www.everbesthk.com/8-download...ade_207_XP.zip
    Download the firmware to flash the IP camera at:
    http://www.northq.com/download/9006/FW-NQ-9006.1009.zip
    Install the software. Use compatibility mode if you are using W7. The application will not run in 64 Bit mode.
    1 - Connect the included cable to the IPCam
    2 - Install the camera on the same network switch as the upgrading machine.
    3 - then insert a paperclip into the reset hole on the side of the unit.
    4 - While holding down the reset button, plug in the power adapter.
    5 - This will put the device into a firmware upgrade mode.
    6 - The power light should flash while the network light should stay solid
    Firmware upgrade
    1 - You have the run the updater as THE administrator, not just as an administrator in MS Windows 7
    2 - Open the Upgrade Utility app you installed earlier,
    3 - select your current network adapter, the click browse targets.
    4 - If the application finds the device,
    5 - click on the Files button then
    6 - navigate to where you saved the firmware file.
    7 - Once you're ready, click on upgrade.
    8 - It should wipe the EEPROM, write the new firmware, then
    9 - verify that the image has been written successfully.
    The process should take about 5 minutes or so. When it's finished, the device will reboot and once the power and network lights are solid, you should be good to go.
    It will pull an IP from your DHCP server. The login is "Administrator" with no password (Blank).
    This is the default screen of the IP Camera once you've updated the firmware.
    Users of MS IE will need to download an activex component to use the camera.
    References:
    http://slickdeals.net/forums/showthr...d=0&p=37696463
    http://www.sercomm.com/SWI/GUI/PROD_IPS.htm
    http://www.northq.com/docs/NQ9006-installation.pdf
    Plugins:
    BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.
      No; try a XP boot diagnostic disk and see if that helps you. Here's a link I found doing a Google search.
      http://slickdeals.net/forums/showthr...576933&page=17
        For those with problems getting things to work under Windows 7
        On my Windows 7 64 bit I loaded vmware and then loaded XP professional as a VM.
        It has solved a number of problems includding the ELK security administration software.
        Never could get them to work in compatability mode under Windows 7
          installed xpPro on virtual machine. thanks for the tip. I installed the software, but in the instructions for flashing the firmware # 3 says,
          I never saw that...all i see is browse or exit. I am able to to get the device in flash mode, at least based on the power light flashing and the network light being steady. When I try to browse targets nothing shows up. any clues?
          Ian
          Plugins:
            You have to see the MAC address of the camera via the virtual NIC on the VM. Try shutting off the "default" enabled firewall on your XP VM and see if that works.
              Pete,
              Thanks for the tip - no luck though.
              Plugins:
                Not sure what's wrong w/my virtual machine, but I threw xpPro (the same one I put on the virtual machine) onto a laptop I have sitting around, and it was able to find the camera, so now I'm flashing 8 of them, and the fun starts!
                Ian
                Plugins:
                  Good news there Ian.
                    I'm be incorrect but I was checking on my firewall and I noticed that these cameras are making connections to this location see print screen, including the internal ip cameras.
                      I see the same from the Camera. Its literally blasting the firewall every few seconds. I don't know what to make of it. Its using port 8802.
                      78.109.216.253 (0x4E6DD8FD.cust.taanx.net.vipgroup.dk)
                      BW whois 5.0 by Bill Weinman ([url]http://whois.bw.org/[/url])
                      Copyright 1999-2006 William E. Weinman
                      Request: 78.109.216.253
                      connected to whois.arin.net [199.71.0.47:43] ...
                      connected to whois.arin.net [199.71.0.46:43] ...
                      # Query terms are ambiguous.  The query is assumed to be:
                      #     "n 78.109.216.253"
                      # Use "?" to get help.
                      # The following results may also be obtained via:
                      # [url]http://whois.arin.net/rest/nets;q=78.109.216.253?showDetails=true&showARIN=false[/url]
                      NetRange:       78.0.0.0 - 78.255.255.255
                      CIDR:           78.0.0.0/8
                      OriginAS:
                      NetName:        78-RIPE
                      NetHandle:      NET-78-0-0-0-1
                      Parent:
                      NetType:        Allocated to RIPE NCC
                      Comment:        These addresses have been further assigned to users in
                      Comment:        the RIPE NCC region. Contact information can be found in
                      Comment:        the RIPE database at [url]http://www.ripe.net/whois[/url]
                      RegDate:        2006-08-29
                      Updated:        2009-05-18
                      Ref:            [url]http://whois.arin.net/rest/net/NET-78-0-0-0-1[/url]
                      OrgName:        RIPE Network Coordination Centre
                      OrgId:          RIPE
                      Address:        P.O. Box 10096
                      City:           Amsterdam
                      StateProv:
                      PostalCode:     1001EB
                      Country:        NL
                      RegDate:
                      Updated:        2011-03-15
                      Ref:            [url]http://whois.arin.net/rest/org/RIPE[/url]
                      ReferralServer: whois://whois.ripe.net:43
                      OrgTechHandle: RNO29-ARIN
                      OrgTechName:   RIPE NCC Operations
                      OrgTechPhone:  +31 20 535 4444
                      OrgTechEmail:  [email]do_not_email@ripe.invali[/email]d
                      OrgTechRef:    [url]http://whois.arin.net/rest/poc/RNO29-ARIN[/url]
                      # ARIN WHOIS data and services are subject to the Terms of Use
                      # available at: [url]https://www.arin.net/whois_tou.html[/url]
                        I am seeing the same thing. I have 2 cameras and they are both sending something to 78.109.216.253
                        I added this URL to the "blocked" list in my router.
                        Steve Q
                          It seems that the nq is getting info constantly on that port. Not sure what. I blocked tha port but i m curious on what info they are collecting. I have 5 cameras.
                            That's a bit concerning - is there anyway to capture some packets to see what it is sending?
                              I think we are all using the same software that we got from the link posted in this thread. I have a feeling it is infected with a virus that is probably trying to send information; perhaps the IP address of the camera. Perhaps its harmless, but maybe not! I can't tell if my router is successfully preventing it from sending or not. All I can see are many log entries in the outgoing log; even after I added the IP address to the "blocked" list.
                              I agree we need to find out what information is being sent.
                              Steve Q
                                I'll throw Sniffer Pro on it and see what its sending. I don't think its a virus though.
