Grand Concerto Humm
    Grand Concerto Humm
    I imported a Grand Concerto from the USA and am running it through a transformer to Convert our 220 Volt to the USA 110 Volt. I brought the unit some time and had a brain dead moment when I plugged it in and I connected to the 220 Volt. I'm so used to dual voltage power supplys anyway it blew the fuse. I replaced the fuse and now have it running on 110 Volt. All appears well keypads work but I get a humm out of the speakers even with no sources attached. Can anyone suggest anything ?
    First place I look when trying to trace a hum is a ground fault. Is the unit grounded well? Maybe something happened to the ground as well as the fuse when you plugged into the 220 line?
    Marty
      No Ground
      Interestingly the unit has no ground in the power cable. I read somewhere it doesn't need one. Do you think I should try one anyway ?
        I'm not at all familiar with the grand concerto but when I get a hum on audio equipment of any kind that's where I start looking. I must have had an internal ground or maybe it was isolated in some way. Hopefully someone who knows that unit will chime in.
        Marty
