MouseClick script?
    MouseClick script?
    Is there a mouse click script already that I've missed?
    I just thought I'd ask before reinventing the wheel...
    I've used AutoIt and Mortscript for that.
    --Dan
      But I'd like to do it "directly" in .NET. I've already written such an application, I'd just convert it to a script...
        If you need to click the mouse this is what I did in .net;
        PHP Code:
        Declare Sub mouse_event Lib "user32" Alias "mouse_event" (ByVal dwFlags As LongByVal dx As LongByVal dy As LongByVal cButtons As LongByVal dwExtraInfo As Long)
        Sub Main(ByVal Sval as String)
        Windows.Forms.Cursor.Current.Position = New System.Drawing.Point(225105)
        hs.waitsecs(2)
        Call mouse_event(&H20001)
        hs.waitsecs(1)
        Call mouse_event(&H40001)
        End Sub
        Which clicked the mouse at the co-ordinates in the system.drawing.point (left click down and 1sec later left click up), need to have the system.drawing dll reference in HS though...
        I got from somewhere on the net, can't remember where though sorry.
          This script should work with the script connector plugin, with a #IMPORT at the top for the System.Drawing dll.
          stipus
            Yeah, that's what I'm trying to achieve here, but I'll guess I need some #imports sorted out:
            http://forums.homeseer.com/showthread.php?t=142632
              I figured it out:
              #IMPORT System.Drawing,system.drawing.dll
              #IMPORT System.Windows.Forms,system.windows.forms.dll
              Private Declare Sub mouse_event Lib "user32.dll" (ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal dwData As Long, ByVal dwExtraInfo As IntPtr)
              Private Const MouseEventLeftDown As Int32 = 2
              Private Const MouseEventLeftUp As Int32 = 4
              Public Sub Main(ByVal param As Object)
                  Dim params() As String = param.ToString().Split("|")
                  If params.Length > 2 Then GenerateMouseClick(params(0), params(1), params(2))
              End Sub
              Private Sub GenerateMouseClick(ByVal x As Integer, ByVal y As Integer, Optional ByVal mouseclicks As Integer = 2, Optional ByVal return_mouse As Boolean = True)
                  Try
                      If mouseclicks < 1 OrElse mouseclicks > 3 Then
                          hs.WriteLog("MouseClick", "Only 1, 2 or 3 mouse clicks are allowed")
                          Exit Sub
                      End If
                      Dim pointOldPosition As Point = Windows.Forms.Cursor.Position
                      Windows.Forms.Cursor.Position = New Point(x, y)
                      For i As Integer = 1 To mouseclicks
                          mouse_event(MouseEventLeftDown, 0, 0, 0, New System.IntPtr())
                          mouse_event(MouseEventLeftUp, 0, 0, 0, New System.IntPtr())
                      Next
                      If return_mouse Then Windows.Forms.Cursor.Position = pointOldPosition
                  Catch ex As Exception
                      hs.WriteLog("MouseClick", "Error occured. Sorry about that...")
                  End Try
              End Sub
