Multiple errors. Compiler not working on W7 64bit?
    This is the code I want to run. This works perfectly in my standalone (.NET 2.0) program:
    '#IMPORT System.Runtime.InteropServices
    '<DllImport("user32.dll")> _
    Private Declare Sub mouse_event Lib "user32.dll" (ByVal dwFlags As Long, ByVal dx As Long, ByVal dy As Long, ByVal dwData As Long, ByVal dwExtraInfo As IntPtr)
    Sub Main(ByVal param As Object)
        Dim params() As String = param.ToString().Split("|")
        GenerateMouseClick(params(0), params(1), params(2))
    End Sub
    Private Sub GenerateMouseClick(ByVal x As Integer, ByVal y As Integer, Optional ByVal mouseclicks As Integer = 2, Optional ByVal return_mouse As Boolean = True)
        Try
            If mouseclicks < 1 OrElse mouseclicks > 3 Then
                hs.Writeline("MouseClick", "Only 1, 2 or 3 mouse clicks are allowed")
                Exit Sub
            End If
            Dim pointOldPosition As Point = Windows.Forms.Cursor.Position
            Windows.Forms.Cursor.Position = New Point(x, y)
            For i As Integer = 1 To mouseclicks
                mouse_event(MouseEventLeftDown, 0, 0, 0, New System.IntPtr())
                mouse_event(MouseEventLeftUp, 0, 0, 0, New System.IntPtr())
            Next
            If return_mouse Then Windows.Forms.Cursor.Position = pointOldPosition
        Catch ex As Exception
            hs.Writeline("MouseClick", "Error occured. Sorry about that..." & ControlChars.NewLine & ControlChars.NewLine & ex.ToString)
        End Try
    End Sub
    I get these errors in the debugging window:
    09:47:01 Executing script: remote_mouseclick.vb
    09:47:01 Compile Error : Scripts\remote_mouseclick.vb : CompilerError[s] :
    line:15 error:BC30456 ''Writeline' is not a member of 'Scheduler.hsapplication'.'
    line:19 error:BC30002 'Type 'Point' is not defined.'
    line:20 error:BC30451 'Name 'Windows' is not declared.'
    line:20 error:BC30002 'Type 'Point' is not defined.'
    line:23 error:BC30451 'Name 'MouseEventLeftDown' is not declared.'
    line:24 error:BC30451 'Name 'MouseEventLeftUp' is not declared.'
    line:27 error:BC30451 'Name 'Windows' is not declared.'
    line:29 error:BC30456 ''Writeline' is not a member of 'Scheduler.hsapplication'.'
    line:29 error:BC30451 'Name 'ControlChars' is not declared.'
    All the types are missing. And what is going on with "Writeline"?
    EDIT: I must be doing something wrong. But what?!?
    The sample scripts works...
    Try to add a #IMPORT at the top for system.drawing.dll
    #IMPORT System.Drawing,system.drawing.dll
    For the Writeline error, check the casing. I think it's WriteLine
    stipus
      Thanks, it was a capital L missing in WriteLine.
      BUT; I'm having problems with this line:
      which gives the error:
      1:39:00 Compile Error : Scripts\remote_mouseclick.vb : Error in #IMPORT Namespace,Dll Statement
      But System.Runtime.InteropServices is (according to my google search) a part of mscorelib.dll and shouldn't need to be referenced.
      When I try it, I get this:
      11:40:03 Compile Error : Scripts\remote_mouseclick.vb : CompilerError[s] :
      line:-26 error:BC2017 'could not find library 'mscorelib.dll''
      line:-26 error:BC2000 'compiler initialization failed unexpectedly: 0x80070002'
        This works:
        #IMPORT System.Windows.Forms,system.windows.forms.dll
        Private Const MouseEventLeftDown As Int32 = 2
        Private Const MouseEventLeftUp As Int32 = 4
        Public Sub Main(ByVal param As Object)
            If params.Length > 2 Then GenerateMouseClick(params(0), params(1), params(2))
        End Sub
            Try
                    hs.WriteLine("MouseClick", "Only 1, 2 or 3 mouse clicks are allowed")
                    Exit Sub
                End If
                Next
                hs.WriteLine("MouseClick", "Error occured. Sorry about that...")
            End Try
        End Sub
        BUT: If I don't comment out the WriteLine lines, I still get get these errors:
        12:04:28 Compile Error : Scripts\remote_mouseclick.vb : CompilerError[s] :
        line:19 error:BC30456 ''WriteLine' is not a member of 'Scheduler.hsapplication'.'
        line:33 error:BC30456 ''WriteLine' is not a member of 'Scheduler.hsapplication'.'
        EDIT: And that is because I'm an idiot! It's not WriteLine, it's WriteLOG!
          Try using hs.Writelog
          EDIT - I see you already discovered that!
          Jon
