Jon00 Homeseer 2 web page (Quick view) builder Version 2
    #31
    Jon, the new version straightened out all my little troubles, thank you!
    Of course you knew there was a question comming up.
    I tried the page without showing the links at the top and I liked that a lot better. It made it so much more view-able on a PPC. I did really miss the HS title bar though.
    Is there a way to show the HS title bar only, without the buttons for plugins and such?
    Marty
      #32
      You cannot do that with the current version but if I need to update it I will add this feature if you wish.
      Why not just have another ini file for your PPC not showing the header (you can define a single control button if you want to exit)?
      Jon
        #33
        That's what I am doing. I have a separate ini that I only use for the PPC and getting rid of the buttons makes it a lot nicer to view. Since I won't be configuring anything on the PPC just viewing status i don't need any of the buttons but I did miss the HS Title Bar, I miss the cute little sun moon dates and time. It's not a biggie, just something I missed looking at the plain quickview. I have all the info I need showing, now just working on it's looks a little bit.
        Marty
          #34
          You could always roll your own logo bar as a header assuming you are only using one column for your PPC:
          In your buildpage.vb, add the following immediately before the line:
          '******* User defined here *****
          PHP Code:
          'Variable 50 - LogoBar
          Try
              strVar = "<table border='
          0' cellpadding='0' cellspacing='0' width='100%'><tr>"
              strVar += "<td class='
          logobar' colspan='1' >&nbsp;<span><span><img src='/images/HomeSeer/clock.gif' align='absmiddle' border='0'>&nbsp;" & Now() & "</span>"
              strVar += "</span><span>&nbsp;<img src='
          /images/HomeSeer/sunrise.gif' align='absmiddle' border='0'> <b>Sunrise:</b> " & hs.sunrise() & "</span>"
              strVar += "<span>&nbsp;<img src='
          /images/HomeSeer/sunset.gif' align='absmiddle' border='0'> <b>Sunset:</b> " & hs.sunset() & "</span>"
              strVar += "</td</tr></table>"
              hs.SaveVar ("BPVar50",strVar)
          Catch ex As Exception
              If Logging=1 then hs.writelog("Jon00_Buildpage","Error at BPVar50 (" & ex.Message & ")")
          End Try
          Now just call up the BPVar50 in a heading i.e.
          Column1Heading1=BPVar50
          Because of colour matching within the existing header, you may need to play with the class='logobar' and change it to class='tableheader' but you should get your requirements even if it does not look exactly the same style as the logo bar.
          Jon
            #35
            Thanks Jon, I'll play with that a bit.
            Marty
              #36
              That worked great, thank you. It's not exact but like you say it's close enough and I can only see so much on that tiny little screen anyway.
              Marty
                #37
                I've just found another bug...I really should have put this out to beta!
                If you set the Heading to "Null" (to hide it), it breaks! I'll have to put out a new version Gives an opportunity to add feature requests
                I've been playing with my iTouch and generated the following test page for it with this package. The status icons/text makes an ideal area to finger scroll down the page!
                Jon
                  #38
                  V2.03 released.
                  Fingers crossed on this one!
                  This is a summary of changes since 2.02:
                  Corrected bug where adding "Null" to a Heading would break the page rather than hide the heading.
                  Added hs.devicetime variable to report the time in minutes since a device last changed.
                  Added HeadData as a new ini setting
                  Added BodyData as a new ini setting
                  Added CSSName as a new ini setting
                  Added RemoveLogoBar as a new ini setting and redefined RemoveLinks as a setting.
                  Added iTouch.CSS and iTouch.ini as an example page for the iTouch
                  Provided a method to define a button style per button on a page.
                  Hopefully I've captured everything!
                  Jon
                    #39
                    Jon,
                    Just updated to 2.03 and now getting an error
                    Error Initializing script run: File 'D:\Program Files\HomeSeer 2\scripts\Logwebpages.vb' not found.
                    Brian
                      #40
                      Oops...
                      Download it again!
                      Jon
                        #41
                        think i missed the upgrade to ver 2.03 but anyway...
                        I have a few questions as im not sure..
                        well now that I just left this post to go look at a few things...
                        reading the doc (go figure) I figured out how to center the text in the heading columns and re arange stuff as I like...
                        but I still have 1 question...
                        how does one just adjust the width of each column in just 1 section?
                        see how my text wraps around? dont want it too....
                        im gonna download 2.03 and install it and read the doc again...
                        ~Jeff
                          #42
                          seems that stretching the first middle column by adding stuff.. made the others wider..
                          the problem I was having was that devices: was too long and wouldnt show.. but if i put Dev: it was fine...
                          Once I added Ver:
                          the line got wider and Devices now fit.....
                          here is another sneak peak..
                          once i get all of them done I will post up as you requested for people to share...
                            #43
                            The width of the left sub-column is defined using:
                            ColumnXSectionXWidthLeft=xxx in pixels
                            The width of the next is defined using:
                            ColumnXSectionXWidthRight=xxx in pixels
                            If you look at the sample qv.ini file it shows all the possible ini file settings. Also read the docs - or as I aways say to TrOjAn RTFM...everything is explained
                            Jon
                              #44
                              Aren't the first two columns width determined by these two setting in the ini file, for each section?
                              Column1Section1WidthLeft=
                              Column1Section1WidthRight=
                              I think the rightextra column just gets whats leftover.
                              Marty
                                #45
                                I'll be damned, Jon beat me to it, i was even right. It's gonna be a good day.
                                Marty
