I thought as much...
however, you never know if you don't ask!
Thanks again Stipus!
--Dan
--Dan
Sub main() set Winamp = CreateObject("WinampCOM.Application") Winamp.Play End sub
Sub main( param As Object ) Dim Winamp as Object = CreateObject("WinampCOM.Application") Winamp.Play() End sub
Sub Main( param ) Dim result As Object result = hs.Plugin("Script Connector").ExecFunc( "ClientName", "remote_test_func.cs", Nothing ) hs.WriteLog( "Result CS", result) result = hs.Plugin("Script Connector").ExecFunc( "ClientName", "remote_test_func.vb", Nothing ) hs.WriteLog( "Result VB", result) End Sub
Function Main( param As Object ) As Object Main = "Hello from Remote VB Script" End Function
object Main( object param ) { return "Hello from remote CSharp Script"; }
