Ken,
thanks for the thoughts.. when it comes down to it I really only need the power on and power off commands, as well as picture mode and aspect..
From what you wrote above it seems that the picture mode will be the most challenging out of them all.
not sure if this help or not..
As far as the Pioneer script goes, any idea where I should start so that I can make the script more compliant with my unit. Obviously the send commands work fine, its the getting responses that I have issues with. Like I said above most things works fine, however the simple command, PWR does not get the correct response.
